New Evo ECU tuning article
Hey guys,
Look what i found on the Works site
http://www.worksrally.com/index2.php.../articles.html
The Works team approach to ecu tuning, interesting thread
Btw, my wife is complaining that i am on the web surfing too long looking at the different venders website, and not with her except when i need something
Bye!
Wilson
Bye!
Wilson
Re: New Evo ECU tuning article
Originally posted by wilson1
Hey guys,
Bye!
Wilson
Hey guys,
Bye!
Wilson
Wilson, your wife and mine must be talking, because I constantly get the evil-eye anytime I get near the internet!!
N10S
Originally posted by BushBurninEvo
another reason i should get the P2
Already scheduled for release, WORKS will be offering custom duration cams (not the usual 264s and 272s offered elsewhere on the market), controlled by the Brain Flashed factory ECU.
We will also be rolling out the WORKS turbo kit (no, not the usual GT 30/37 offered by everyone else, but something truly special and unique), again, controlled by the Brain Flash.
Water Injection is coming out very soon, with, you guessed it, custom mapping controlled entirely by the Brain Flash.
So, for those of you who thought there would be a ceiling of what the Brain Flash could control, you're in for a pleasant surprise.
-- DavidV
Wow David, you guys are full of surprises! The idea of being able to buy custom cams and a turbo upgrade kit, all tied together with an optimized re-flash will be an awesome thing for sure!
N10S
N10S
N10S
N10S
-- DavidV
Originally posted by DavidV@WORKS
We have made some really good progress on both the water injection and custom cams this past week, so keep an eye out for those products soon as we are already into the evaluation stage on what is now looking to be the final prototypes on each of those.
-- DavidV
-- DavidV
Also, it is becoming more and more apparent, with the dynos and testimonials being posted, that the Evo benefits from an upgraded fuel pump. Now I know the average owner isn't going to pay more than $120 for a fuel pump when the 255 lph Walbro unit seems to not only shine, but brings to the table a proven track record. Has Works, or will Works offer all their programs with an adjusted tune with these fuel pumps? It's also become quite apparent that the top end needs to be leaned out a good bit due to the upgraded pumps ability to maintain a health fuel flow over 8000 rpm. Hence, you cannot just add the pump to a base program with out running too rich.
Good points Zeus. Just like the fuel pump it's been pointed out in some other threads that larger injectors may be necessary with the installment of cams. Of course, luckily for us, that could all be easily adjusted in the ECU.
Does Works have any insight on the the injector duty cycle with cams vs. when larger injectors are needed?
Originally posted by Zeus
I reached for the phone to order the P2... then I saw this... Now I'm thinking that I might wait for the flash with cams. My question is this though... I plan on replacing the head bolts with stronger ARP head studs when I do the cams. I'm already looking at replacing the rod bolts with their upgraded units due to the higher rev range that the P1 has. With that in mind, can I get a flash with boost mapped in the low to mid 20-psi range?
Originally posted by WildRice
excellent Dave.... valve timming and water injection.. attaway to hot rod. Leaning out the f/a by replacing fuel with water should ease demand on the injectors should it not?
-- DavidV
