MAF screw ADJ. David comment plz
David if we adjust the screw under the MAF hidden under the silicone how will it be affected by the p1 or p2. Have you tried playing around with this at all?
I would recommend against the modification you are describing as it changes the air/fuel values across the board -- including under idle and part throttle conditions. In addition, the types of values that we are dialing into the A/F ratio on the Brain Flash are very highly tuned and would neither require, nor benefit from, this mod.
-- DavidV
-- DavidV
