3" Downpipes now in stock $299!
As an addition to the WORKS Labor day sale (through Sept. 10th), the new 3" downpipes are being offered at special introductory prices!
Ceramic Coated $399 normally $449
Brushed Stainless $299 normally $349
All hardware (including adapter for stock O2 sensor housing) is included, along with instructions.
If your road racing or drag racing go with the 3" but if your Autoxing stick with the 70mm pipe. Like everything else it really depends on what or how your going to use the car.
Originally Posted by mayhem
EM & Tyler,
At what point would using the 3" be an advantage over the 2.75"? If your ultimate goal is the 340 package should we stick with the 2.75?
Another reason is the price. The 3" downpipes are less expensive to produce, so we pass the savings on to you.
Originally Posted by CanyonEvo
Tyler,
what's an approximate price and ETA on the new O2 housings??
thanks.
thanks.
Any pictures of the stock O2 housing. I have no idea where it is or how it looks. From what I'm reading I guess it's in line with the DP (in exhaust line like all O2 sensors). Is it not mounted in a bung like others?
In the meantime, the Exhale 76mm downpipes are in stock and on sale. These include a new enlarged exhaust donut that fits to your stock O2 housing with the included adapter. Down the road when if you decide to get our upcoming O2 housing, simply remove the adapter and drive.
Originally Posted by caymandiver75
Will this new 02 housing fit any 3" downpipe?
02 housing with 2.5" exhaust??
Originally Posted by Jamie@WORKS
We can't say it will fit any other downpipe due to the fact that WORKS uses a larger donut gasket than OEM with our Exhale 3" DP. If other pipes are able to accomodate this gasket, then they should be compatible.
Originally Posted by boomn29
For those of us that have 2.5" exhaust - are we out of luck on this mod??
