Aluminum shifter base bushings and brass shifter cable bushings Install
Old Jan 10, 2013, 06:13 PM
rad100's Avatar
yeh but the lever on mine doesnt have a hole through it to put a pin through. its got a groove around it. the top lever was fine, had a hole and i put the pin back. but the bottom doesnt have the pin hole.
must be a jdm thing?
Old Jan 12, 2013, 04:32 PM
CrAnSwIcK's Avatar
should have a hole through it for the pin...i don't see why they would make it different for JDM...
Old Mar 14, 2016, 11:30 AM
Buggin's Avatar
Not sure why, but my bushings were way too small and couldn't lock into place. Even tightening them all down, my shifter base would slide around about a 1/4" as I tried going through the gears. I had to put the factory rubber ones back in.
Attached Thumbnails Aluminum shifter base bushings and brass shifter cable bushings Install-image.jpg
Old Mar 14, 2016, 12:22 PM
CrAnSwIcK's Avatar
dude, it looks like someone drilled out the shifter base...also they should be a 2 piece bushing. Either you got the wrong parts, or you installed them wrong...but it looks ****ed, and probably needs to be replaced.
Old Mar 14, 2016, 12:28 PM
Buggin's Avatar
Those are the ones speed source sent me maybe there are two different sizes? The under hood ones fit just fine. Yes there are two pieces each hole. I left the top one off to show the size difference. The stock rubber ones fit in those holes snug. I don't think anyone has drilled them out.
Old Mar 14, 2016, 08:52 PM
CrAnSwIcK's Avatar
are they two different sizes? the bushings and the holes in the shifter base should all be the same size...in the pic you posted the shifter base hole on the left is significantly larger in diameter, and eccentric than the one on the right, which looks normal, that's where your slop is coming from...either that was hacked, or improper bushing installition cause it to wear like that...you need a new shifter base.
Old Mar 15, 2016, 05:48 AM
Buggin's Avatar
All four holes are the same size. The bushing on the left just isn't centered like the one on the right. I am thinking the bushings are too small as the stock rubber ones are tight in the holes.
Old Mar 15, 2016, 07:17 AM
CrAnSwIcK's Avatar
if they are Evo 8/9 shifter base bushings they should fit tight. if they are the wrong size I would definitely give speed source a call...
Old Mar 15, 2016, 08:46 AM
bakuro117's Avatar
I dont have speed souce ones. but my shifter base bushings are two piece. And they have a lip milled into them so that they actually sort of pop into the shifter base. looks like you have some parts missing.
Old Jun 1, 2017, 09:07 PM
Blue_Lion's Avatar
Locating shifter cable bushings on 04 RA
Sorry If this is the wrong thread to post on, just had a quick question. Recently bought and installed works short shifter for the Evo 8 on my 04RA along with works base shifter bushings. I also bought the hybrid shifter cable bushings from works as well, was wondering if these will even fit.. http://store.worksmotorsports.com/mo....aspx?id=38710
there was a sale on MAP and so I said why not.
I was able to install the other two because there were detailed how to's along with pictures and videos too. When it came to setting up the cable bushings I couldn't find then.. or didn't know what I was looking for tbh and I was wondering if you guys could help.. thanks
Billy's MR
Feb 28, 2017 08:00 AM
e_kobz
May 3, 2016 11:22 AM
bolsen
Jun 2, 2008 06:13 PM
DangerousDan
Aug 10, 2006 09:01 AM
PDXRalliArt
Jun 25, 2004 01:16 PM
Quick Reply: Aluminum shifter base bushings and brass shifter cable bushings Install
