mirage with 4g69 mivec turbo
So you've made 380 on stock internals?! that's pretty awesome! We were just recently discussing how the pistons must be the weak link in our internals.
I am preparing to start my turbo build and have been debating what psi to aim for in a daily setup. I was thinking 10-12. But youve kinda built up my confidence a little more!
Almost 380 but its not safe.
The rods are too thin and the pistons wont resist too much.
i upped boost to 10psi maf volts are same as they were at 6psi 4.7 it took s a bit of fiddling with the MAF scaling but all is well now. MAF Scaling is 4.7v and 260.8g/s but my MAF size is 475g/s i am still figuring it out i may have the numbers backwards but it s fueling well hitting the target.
Do you mind sharing what Kind of timing curve are you runing in the tune?
maybe share a map of it or a log?
We have a mirage turbo, forged internals, evo 9 turbo, cams, with some custom parts, etc
but are having a hard time tuning the car to its full potential
It would be really nice to share some info, if you are ok with it.
PM Works also!
thanks
PM Works also!
thanks
Ask my friend who posted my car here. maybe he could help u out.
PM Works also!
thanks
PM Works also!
thanks
No i didnt,was all stock
Sadly the stock pistons couldnt handle that power for much time, they handle at most 310whp
I made 312whp @10psi
But i was cocky and wanted more and they went BOOM
you made 312 at 10psi? if your AFR's were safe, you must have been running A LOT of timing...
I blew my engine at 18psi with a 20g turbo...i'm fairly certain now that it only blew up because my meth/water injection pump failed... I ran 14psi for years, racing nearly every weekend with zero issues on 94 octane fuel, without water/alcohol injection...
do you have any datalogs from when it was running?
