04-06 Ralliart Aftermarket Forced Induction Tech (aftermarket turbo/supercharger related topics)
mirage with 4g69 mivec turbo
Old May 9, 2014, 07:26 PM
danny1058's Avatar
here is some pics of my friend's car that i tuned, i need to fix the A/F line but the car have some electric problems...
Attached Thumbnails mirage with 4g69 mivec turbo-technica-mivec.jpg   mirage with 4g69 mivec turbo-technica-mivec-3.jpg   mirage with 4g69 mivec turbo-technica-mivec-1.jpg   mirage with 4g69 mivec turbo-technica-mivec-4.jpg
Old May 10, 2014, 05:29 AM
CrAnSwIcK's Avatar
looks like a clean install...interesting having the compressor facing the passenger side...looks like the STR cast manifold...
question though, what did he do with the alternator?
Old May 10, 2014, 07:07 AM
bakuro117's Avatar
That is sexy!!! I'm also curious about the alt. I bet this thing is quick!!! Lol
Old May 10, 2014, 10:19 AM
CrAnSwIcK's Avatar
that's a big snail too...is the engine built?
Old May 10, 2014, 11:10 AM
bakuro117's Avatar
Does it not have AC or power steering either? Drag car or daily?
Old May 10, 2014, 11:21 AM
High_PSI's Avatar
That's the 4 CLY that cam in the Eclipse?
Old May 10, 2014, 01:11 PM
CrAnSwIcK's Avatar
yeah, 4g (2006+) Eclipse GS, but originally in the 2004-2006 Lancer Ralliart (VRX)
2.4L SOHC with Mivec...the block is nearly identical to a 4G63, only it's a semi-open deck with 87mm bore...deck height is the same, and all fasteners and parts from 4G63 will bolt on, even a DOHC head from an Evo 8 or 9.
Old May 11, 2014, 08:12 AM
2006_RA's Avatar
As you said, nearly the same block, on a 4G63 the alternator and power steering pump are between the firewall and block. Look closely in the 2nd pic.
Old May 11, 2014, 10:15 AM
CrAnSwIcK's Avatar
oh...there's the alternator...
Old May 12, 2014, 05:33 PM
danny1058's Avatar
i think the car doest have a/c, and power steering, he change the rack & pinion of p/s for the economy one mirage, doest bring p/s.
Old May 18, 2014, 05:50 PM
Joe4g69's Avatar
Hey guys, im its owner :)
And yes the car acts as a daily, no A/C nor power steering. Those were removed.
Its stock internals with a gt35 dual ballbearing turbo 70/82ar . It will improve now that the problem was found.
and yes its mad fast.
Old May 18, 2014, 06:57 PM
Joe4g69's Avatar
Yes its a daily but i dont use it much because driving around without A/C here is horrible lol.
Old May 18, 2014, 08:48 PM
CrAnSwIcK's Avatar
LOL! I bet it is...I have A/C, but it doesn't work...here it's not so bad...windows down, and you're good to go.
I'm really impressed with that turbo setup, mine is not nearly that clean, but I didn't need to remove or relocate anything in the engine bay, and it felt good to build it from scratch. I will maybe change a few things around. At one time, I had that same manifold.
Old May 18, 2014, 09:29 PM
Joe4g69's Avatar
How much whp u running?
I can get 380@ 16psi easily now, but wont because stock pistons are crappy.
Old May 19, 2014, 05:07 AM
bakuro117's Avatar
So you've made 380 on stock internals?! that's pretty awesome! We were just recently discussing how the pistons must be the weak link in our internals.
I am preparing to start my turbo build and have been debating what psi to aim for in a daily setup. I was thinking 10-12. But youve kinda built up my confidence a little more!
Quick Reply: mirage with 4g69 mivec turbo
