04-06 Ralliart Engine/Drivetrain (no forced induction)
New motor mounts and engine moves like crazy
Old Nov 16, 2015, 07:29 PM
Ralli_Red's Avatar
I bought new factory motor mounts . But I have a stage 4 clutch and the torque just moves the motor mounts like nothing . I had my ac on and when I floored the car the motor moved upwards and the ac compressor hit on the frame and it made a loud clunk and now my ac compressor sounds like a squeaky belt . Do you guys have any recomendation on motor mounts so my engine doesn't move up like that . I heard you can fill with urethane and it will be solid but I'm not sure ! And also does the evo front mount fit are car ? Hope someone can help out
Old Nov 17, 2015, 09:25 AM
bakuro117's Avatar
Urethane filling works.
Evo front motor mount works.
Blox front mount works great too.
Either way really. Id just recommended trying the urethane mounts. I filled my rear mount and it works great. I used the blox on the front.
Old Nov 17, 2015, 12:59 PM
Ralli_Red's Avatar
Is the blox the one that they call billet ? And thanks so much bro I'll fill my rear with urethane . Did you use 3m ?
Old Nov 17, 2015, 04:37 PM
bakuro117's Avatar
No problem. Yep 3m window weld. Id just do the front and rear with it if you have the time to let the urethane cure. cheap and gets the same results...
02ES=>09RAL
Nov 2, 2014 06:50 PM
EvoDan2004
30
Sep 23, 2013 01:57 PM
CatalystGod
May 13, 2009 09:16 AM
Speed Element
10
Jul 8, 2008 05:03 PM
TTP Engineering
15
Jul 11, 2007 02:48 PM
Quick Reply: New motor mounts and engine moves like crazy
