Brakes and Wheels FYI - Read first
Old Sep 7, 2009, 07:41 PM
  #31
qlitv's Avatar
Originally Posted by parrishr13
this might be a stupid question, but i cannot find a straight answer anywhere.
so, i want to get 03-06 evo wheels for my RA, and from what I understand, they should fit w/different size tires - is this true?
they are 17" x 8" and are 5 x 114 mm or 4.5" bolt pattern with I believe a +35 mm offset
They will fit with a 215-45-r17 tire with just a lil bit of plastic rub.... I can prove it cuz I have them on my RA
Old Sep 8, 2009, 06:40 AM
  #32
turboimports's Avatar
I think that clears up a lot of things. Thanks.
Old Sep 11, 2009, 04:51 PM
  #33
Raikiri's Avatar
Sorry to ask but does anyone know what size lug our tires use? I cant seem to get this one tire off so I'm thinking of taking a breaker bar to it and I cant seem to find what size ratchet-head I'm going to need.
Old Sep 14, 2009, 06:47 AM
  #34
BlackRaven's Avatar
IIRC, 21mm.
Old Sep 14, 2009, 08:36 AM
  #35
EvoM Administrator
otter's Avatar
Yup, 21mm.
Old Sep 28, 2009, 12:05 PM
  #36
austenm's Avatar
I want to run 17 x 7 with a +35 mm offset, any body running anything similar?
Old Oct 31, 2009, 12:14 PM
  #37
bRIBEGuy's Avatar
I'm looking to pick up a new set of rims/tires for my '06 Ralliart Sportback, and have had my eye on a set of 17x7 Enkei EDR9's.
This whole "offset" ordeal has left me fairly confused and overwhelmed, and as such, I know find myself second guessing everything.
The rims recommended for my car on tirerack.com came up as having a +45mm offset, and a 5.74" backspacing.
Does this sound about right? I'm looking for something that will bolt up with no rubbing/issues. I had intended to run a 205/45R17 tire (though now I'm also wondering about 215/40R17).
Any assistance would be GREATLY appreciated.
Old Oct 31, 2009, 06:48 PM
  #38
roblaza's Avatar
i'm runnin a 17x7 with a +48 offset on 205/40/17's with NO issues on stock suspention...
Old Oct 31, 2009, 09:08 PM
  #39
EvoM Administrator
otter's Avatar
I'm willing to bet you have some rub marks on the inner rear up against the strut housing. I have a +45 16x7 wheel and it only has about 1mm clearance.
Old Nov 1, 2009, 08:58 AM
  #40
bRIBEGuy's Avatar
Damn......one says good, one says nope.
Decisions, decisions..........
Old Nov 1, 2009, 09:06 AM
  #41
roblaza's Avatar
i can go lock to lock while going over bumps, in and out of driveways, over speed bumps and there's no noise, no binding and no rub marks anywhere that i can see... no noise or binding from the rears, no marks, nothing... the dealership even looked it all over a few days about cause there's clunking from a rear strut and they would have said something if my tires were contacting anywhere...
Old Dec 24, 2009, 06:37 PM
  #42
Raikiri's Avatar
would the 17x7 +48 fit with fender rolling? i found some wheels that look pretty nice that i may want to get. then again i think being lowered would make it even worse...
Old Jan 15, 2010, 06:52 PM
  #43
EvoM Super Moderator
lanzerralliart's Avatar
I found some big brake kits a horsepowerfreaks for the ralliart up to 16 inch rotors and 12 piston calipers they are a bit more than 3 k though lol...but u could have braking comparable to a dual laundry shoot dragster... Maybe somehing for LSD once he's finished.
Old Jan 19, 2010, 01:22 PM
  #44
roblaza's Avatar
they're working for me without any fender rolling.... BUT i think this year i'm going to drop the car, roll the fenders and grab some 5mm spacers...anyone have any insight into this?? think it'll work?
Old Feb 19, 2010, 06:24 PM
  #45
JMONK360's Avatar
My setup is tein s-tech springs on 17x7 drag dr16 with 40 offset with kumho ecsta asx 215/45r17. Rubs little when turning hard in parking lots and rubs on fender in the rear if two people sit in the back! so no fat chicks!! Other than that i love the setup. working on getting new tires since the kumho's have 55,000 mi. Time for a new set! anyone have any idea's
Quick Reply: Brakes and Wheels FYI - Read first
