wheel size...
Old Apr 17, 2012, 10:09 PM
Christoph7887's Avatar
wheel size...
soo ive searched the form for about 2 hours now... in the wheel section their are some RAs with 17 inch wheels... is that possiable to do with out heavy mods? like bolt and go? or is more needed to have the smaller wheels on?
Old Apr 17, 2012, 11:08 PM
crankIT's Avatar
Running 17 inch wheels are perfectly fine. Just make sure the bolt pattern fits and there is enough offset to clear the brake calipers. Also, since you are going to a smaller wheel, you need a larger sidewall to compensate in order to maintain accurate speedometer readings. google search 'tire size calculator' to get an idea of what size tire you should be going for. If it were me, I would go for +35-40 offset on an 8-9 inch wide wheel with 235/45/17 tires. That would work with minimal issues (yet still be aggressive) and I don't think you would need to roll fenders at stock height with those specs.
Old Apr 18, 2012, 05:39 AM
Veronica's Avatar
And you should really drop it low if you use a performance/low profile tire or it will have stoopid wheel well gap
What is the reason you are going 17"?
This will help guide discussion...
Old Apr 18, 2012, 01:36 PM
03chi-town0Z's Avatar
245/45r17 is almost exactly the same diameter as the stock tires. It's what I'm running now. If you're worried about fitment and rolling fenders, stick with a 17x8 wheel and somewhere around +45 offset
Old Apr 18, 2012, 08:41 PM
well the reason for 17s is more options in wheels and such i currently looking for wheels to hype up the look of my RA... cause i like the kinda thicker 5 and 6 spoke wheels...
Old Apr 19, 2012, 07:27 AM
Veronica's Avatar
Me too!
I found that five spoke RX-8 fit, Mazda3 and 6 fit us well.
The Nissan (350z) 6 spoke does not
Tire rack had sevral 5 spoke for us (the one i liked was out of production but check again) and search Konig too (i went with Konig Airstrike...)
Old Apr 19, 2012, 09:10 AM
nunyas's Avatar
you can also look at wheels listed for the EvoX as options. Though, for a very large portion of those wheels you may need to roll your rear fenders to make work.
Old Apr 19, 2012, 12:55 PM
sstevojr's Avatar
Originally Posted by Veronica
Me too!
The hub and bolt pattern are the same? 5x114.3 and 67.1 IIRC?
Old Apr 19, 2012, 02:23 PM
RX7 wheels used to be a really popular choice for Evo VIII and IX guys looking for a lightweight wheel for drag racing on a budget, so I'm sure those will work. Not sure about the others, though within a company, they usually tend to keep things similar
Old Apr 19, 2012, 03:26 PM
sstevojr's Avatar
Check out this site I found:
http://www.roadkillcustoms.com/hot-r...NCER+EVOLUTION
Old Apr 20, 2012, 09:25 AM
Veronica's Avatar
Cool find! Thanks for posting it.
Old Dec 17, 2012, 04:19 AM
Laza's Avatar
I went the same way, found a good deal on 2nd hand OZ Ultraleggeras 17x8 ET 45, and since the fitment guide on this forum indicated they'll be a perfect fit I went with them. Tires are 235/45 R17.
I made a test fitting, but they look like they're poking out way too much in the front? Might be that the car/shocks haven't settled in after I raised the car, but it still looks weird and now I'm concerned about the fitment. I tried to take a pic from exactly above the wheel, what do you guys think?
Attached Thumbnails wheel size...-rengas1.jpg   wheel size...-rengas2.jpg   wheel size...-rengas3.jpg
Old Dec 17, 2012, 07:02 AM
That doesn't look like a 45 offset wheel to me. That looks like it sticks out the same as my 245 tire on 8.5 +30 wheels. I'd venture to guess it looks like a 25 offset.
Old Dec 17, 2012, 09:25 AM
nunyas's Avatar
^^^^this looks like ET25 or lower
Old Dec 18, 2012, 12:01 AM
RazorLab's Avatar
Received 1,038 Likes on 760 Posts
Yea no way those are ET45.
There should be a marking on the inside of the wheel, usually on one of the spokes.
Quick Reply: wheel size...
