Ralliart Big Brake Kit (Take 2)
Old Feb 23, 2014, 04:27 AM
  #376
El-Diablo's Avatar
A lot of hard work
Thanks Eric for all the hard work you have put in.
Old Feb 23, 2014, 09:15 AM
  #377
robyn402's Avatar
So its not possible to use a particular grade of steel vice aluminum to skip the expensive anodizing part and just ceramic coat said steel?
Very much apprieciate what you've done with this project just a shame to see this idea not become reality based on the coating required to use aluminum
Old Feb 23, 2014, 09:50 AM
  #378
NFSLancerRA's Avatar
The brackets would weight 10 pounds. It would have to be inch thick steel.
Old Feb 23, 2014, 02:05 PM
  #379
LiX
LiX's Avatar
Why so thick? Steel is stronger than aluminum, so in theory would require less material than aluminum.
Old Feb 23, 2014, 05:39 PM
  #380
They have to be so thick, because you have to offset the calipers so much.
Old Feb 23, 2014, 05:45 PM
  #381
zedd82's Avatar
Would it be possible to use spacers like you did for your original brackets with the C5/C6 calipers?
Old Feb 23, 2014, 05:54 PM
  #382
Nah, the calipers are meant to be mounted right on top of the stock mounting points. You basically have to duplicate this with the bracket.
Old Feb 23, 2014, 08:54 PM
  #383
neogeo64's Avatar
Originally Posted by NFSLancerRA
The other thing is this: If you guys ever have an idea, something you want to make or to have made, let me know. I never charge anyone for design work. It is my hobby, and I do it in my spare time.
Some things I was hoping to see for the Ralliart that no one has made which seem simple to design but for some reason never were produced:
  1. Replacement Metal footrest for LHD Ralliart and Evo X MR that gets rid of the cheap plastic one. (not just some ebay cover)
  2. Master Cylinder brace for LHD Ralliart.
Old Feb 23, 2014, 11:11 PM
  #384
robyn402's Avatar
thats a damn shame, i guess its back to the drawing board for those of us hunting for better brakes
gunna start saving my pennies for an OTS BBK
thanks again for the leg work you put into this
Old May 26, 2016, 06:35 PM
  #385
Dashone93's Avatar
Brackets
can hook me up with brackets
Green_Bandit
21
Sep 9, 2019 02:14 PM
black E
Nov 15, 2016 07:50 PM
timmycat
Aug 30, 2016 12:58 PM
Evo Eric
32
Apr 7, 2016 01:35 PM
Treyzian
35
Mar 31, 2016 10:36 PM
Quick Reply: Ralliart Big Brake Kit (Take 2)
