Ralliart & Evo X MR TC-SST Beta Testing. Flash with Tactrix
Old Feb 10, 2017, 06:59 AM
  #241
dfarmer0033's Avatar
Originally Posted by hearnoevo
how long does it take to do the flash? How many minutes to complete?
The actual flashing process only took me about 10 minutes to complete. Took 30-45 minutes to get everything installed and files put in the right location beforehand.
Old Feb 10, 2017, 07:27 AM
  #242
hearnoevo's Avatar
flash
Thanks for the info, just want to make sure my tablet doesn't run out of battery while in the flashing process. I only have one port so I can't charge while I'm connected to the tactrix cable.
Old Feb 10, 2017, 07:57 AM
  #243
strykr's Avatar
Ya I'd download everything needed ahead of time and than when you get in the car to do it, the process takes 5-10 minutes. Just make sure you record (I took camera pics) of the stock serial #'s and VIN so if you ever need to flash back.
Old Feb 15, 2017, 10:27 AM
  #244
nexstar3's Avatar
Hello,
do you know if the SST Reflash works for a european lancer Ralliart 2011 ?
or all SST is the same ?
Old Mar 7, 2017, 01:24 PM
  #245
dan-lincs's Avatar
Someone further back said they had done it and they was in the UK
Old Mar 8, 2017, 05:31 AM
  #246
dan-lincs's Avatar
Did my 2010 EUDM today - Noticed some slipping 4th to 5th gear... Done teach-in just need to test drive.
Old Mar 18, 2017, 03:40 PM
  #247
dan-lincs's Avatar
Just noticed theres a folder named New CFF - Should we be using them, or the ones from the EVO folder?
Old Mar 24, 2017, 09:40 AM
  #248
hearnoevo's Avatar
ralliart
Is there a file missing in the 2012-2015 ralliart directory? It seems the evo one has three files as well as the other ralliart years but only two in this folder.
Old Apr 26, 2017, 09:20 AM
  #249
hixlancer's Avatar
How are your trannys holding up? Any issues for those that have been flashed for years?
Old Apr 27, 2017, 06:37 AM
  #250
king_cas's Avatar
to further the above question, have the rev hunt/clutch slip issues been ironed out? this post has gotten too large to search through.
Old Jun 9, 2017, 05:18 AM
  #251
Bagle's Avatar
I have not noticed any rev issue, but I haven't been watching my rpms too closely. I definitely do not feel the rev hunting while driving. The tranny is definitely louder while in s-sport, but it holds higher rpms. What I do feel is a far better driving experience while in s-sport manual, possibly the funnest mod I've put on.
Old Jun 9, 2017, 08:10 PM
  #252
Slee256's Avatar
Agree. S-Sport is a great feature that everyone should have on their Ralliart.
Old Oct 14, 2017, 06:56 AM
  #253
robban87's Avatar
Hiya! First off, BIG thanks to vaqusis and everyone involved in creating this guide/procedure! I just flashed Super Sport onto my 2010 Ralliart following this excellent guide, worked like a charm and could not be happier with it!
However, I wanted to do a teach in for good measure, seeing I have also flashed the GST basemap (stock + boost pill) and have about 80000 km mileage on the car. It didn't work. I just got timeout errors for any teach in step I attempted. I tried to search for this error but have come up with nothing. Anyone got any ideas?
Old Mar 29, 2018, 11:19 AM
  #254
wootywoot's Avatar
I believe we are supposed to use the files in the EvoX folder as it appears the new cff files are actually older. If you open the two in a hex editor you can see that the date on the "new" files is from 2009 while the ones in the EvoX folder are from 2011. You can also see the version in the "new" files is 1.01.01 and the EvoX file is 2.01.00. So while it is certainly possible someone has edited the old versions and ported over whatever was changed to get to version 2 it seems to me like the EvoX versions are the correct updated version.
In case anyone wants to double check what I found here are the hashes/info.
EvoX cff file
File: 8631B001_dio30.cff
Hash: 988e269d4744ac89a657139875b57cbc
Version: 02.01.00
Date: 6.10.2011
New Cff Files
File: 8631B001.cff
Hash: 7b2f6ec5075833342552b35eb1f555d2
Version: 01.01.01
Date: 24.8.2009
On that note I just recently flashed super sport mode onto my 2009 Ralliart and have noticed on cold starts my car makes a louder clunking noise then normal and once it even made a worrying grinding noise in place of that clunk. I have read that this was caused by the 5th gear check at start up and cold transmission fluid and was resolved in a TSB. Do the cff files in the gdrive have this TSB implemented (perhaps this is what caused the bump to version 2?)?
Old Sep 18, 2018, 07:53 AM
  #255
superchikn's Avatar
Someone with more computer savvy help out here please.
I got the software installed correctly, but when i go to the step of registry key fix for free use , my file ends at HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node.
There is nothing under it. What have i done wrong , or need to do to fix it?
Quick Reply: Ralliart & Evo X MR TC-SST Beta Testing. Flash with Tactrix
