Installing New Navi / Fuse Bluetooth
Old Sep 22, 2011, 04:47 PM
  #31
franco17's Avatar
any word from the russian hacker community?
Old Oct 20, 2011, 09:36 PM
  #32
ericjai113's Avatar
franco17, did you ever figure out why your handsfree/USB function is gray out in the navi? I just install a (N-05) navigation onto my 2011 GSR and I have the same problem. Did you just have to bring it to the dealer to activate it using the MUT-III tool?
Old Oct 21, 2011, 08:31 AM
  #33
franco17's Avatar
Yes i did, the wire colours the russian tutorial states are wrong. Im in engineering school and havent had time to make a proper write up. Ill try to post the right wires asap. You have to connect the wires to the canbus, not the actual unit itself. The wire numbers are right but not the colours
Old Oct 24, 2011, 10:42 AM
  #34
ericjai113's Avatar
I actually have the FUSE bluetooth system already wired for my 2011 GSR, all I did is just swap the 6-disc CD changer to the Navi headunit. Once you have the wiring corrected, did you have to bring it to the dealer for them to activate it using the MUT-III tool?
Old Nov 5, 2011, 11:12 PM
  #35
NateDaJew's Avatar
I'm a stereo idiot! I have a 08 GSR with navi, will this work for me?
Old Dec 10, 2011, 05:26 PM
  #36
julralliart's Avatar
Someone find an issue with the Bluetooth system and 2010 Nav system ?
Old Dec 22, 2011, 09:12 PM
  #37
nunyas's Avatar
updates?
Old Dec 26, 2011, 11:45 AM
  #38
Krushka's Avatar
Hi. Sorry for very late answer.
Look there: http://asx.2de.ru/90/html/M190103610005100ENG.HTM
Old Dec 29, 2011, 02:00 AM
  #39
Krushka's Avatar
Yesterday I installed FUSE on my Lancer with MMCS. My previous instructions WERE right!! The only thing we need is to modify HARNESS of MMCS. You can see that wires from our small white socket should go to green socket. But female socket DOESN'T have that wires. So you have to add missing wires in order to connect new wires pins 1,10,17 to MMCS green socket pins 106,104,102 respectively. I hope i said it understandable.
BTW. There is no pink wire anymore! I think there is pink wire only on cars with Rockford.
Also I heard that new MMCS harness for Outlander XL already HAS these wires. And it's also suitable for lancer. But I don't know part number, and if it is true.
Old Jan 24, 2012, 07:05 PM
  #40
AWDralliart09's Avatar
Great informations. Thanks!!
Old Mar 2, 2012, 07:11 PM
  #41
bong09's Avatar
Has anyone had any success?
Old Apr 20, 2012, 12:14 PM
  #42
franco17's Avatar
It definitely works . If youve read the entire thread youll see that mine is connected but since the russian wire diagrams have different colours i managed to find a few of the right ones and unfortunately my school semester has kept me more then busy. I just finished my engineering exams yesterday so I will have this 100% working this week. As of now every feature works except for the MIC and the bluetooth/audio only comes through one side of speakers. simple wire mismatch issue.
Old Apr 21, 2012, 07:13 AM
  #43
Krushka's Avatar
It's not an issue. You can check brand new cars at your dealer, the sound of voice commands and handsfree goes only from the right side.
Old Apr 21, 2012, 09:02 AM
  #44
nunyas's Avatar
as stated previously, from the factory bluetooth audio only comes from the right side; assuming you mean phone conversations and not playing music through bluetooth?
Old Apr 21, 2012, 12:56 PM
  #45
franco17's Avatar
music only comes from the right side, usb or bluetooth audio. My wiring is correct it seems my bluetooth unit has damaged solder points from when i desoldered the pins. fixing it now
Quick Reply: Installing New Navi / Fuse Bluetooth
