How do you replace the corner parking lights
Old Feb 18, 2014, 04:07 PM
Cali18933's Avatar
I'm trying to replace the corner parking lights. Can't seem to take off the whole headlights(only way to get to the bulbs). How can I take off the whole headlight to replace it. Or is there a simpler way of replace the corner parking lights.
Old Feb 18, 2014, 09:25 PM
Nast_Nas's Avatar
You should be able to just pull them out. You DO NOT have to remove your headlight. Heres a link to the location, the gray stalk to the left as mention is what the bulb is connected to. http://www.evoxforums.com/forums/showthread.php?t=96914
Old Feb 19, 2014, 06:40 AM
Veronica's Avatar
^yep. 'By Feel'. You will feel the connector as you grope towards the bulb from inside the engine bay. I removed stuff to get to my bulb easier
Old Feb 26, 2014, 10:02 AM
Laza's Avatar
It's also possible to change them through the wheel wells. Just remove 3-4 fasteners on the front side and you can fit your hand between the plastic and the body. The bulb holder comes loose by twisting, and has enough cabling to be pulled out. Changing the bulb is then very easy.
Old Mar 10, 2014, 01:55 PM
JayK's Avatar
Correct, this is how the manual tells you to do this. Its a bit tight to get your arm in there, but just jam it on in and scrape up some knuckles! I put in blue LED lights, which looked sick with the blue paint job. Cops started to give me the eye when i passed them so i went back to ambers.
evox_4x4
Dec 20, 2015 09:42 AM
fusionchicken
Evo X How Tos / Installations
54
Dec 12, 2014 10:18 AM
Hughett
Jul 17, 2014 12:57 AM
cmross13
Jan 19, 2013 06:03 PM
RedlineX79
Sep 14, 2009 07:57 PM
Quick Reply: How do you replace the corner parking lights
