09+ Ralliart Show and Shine Post your pictures, photoshops, and videos!
Ralliart Revitalization - my sportback build up
Old Oct 19, 2009, 04:14 PM
billyboy1's Avatar
Thought it was time to post up a thread of the ralliart build up and will update when the next stages are completed
well, it started with a brand new stock sportback which i knew was a little on the lacking side, but have allocated some coin to addressing those issues the main reason for me for getting the ralliart over an evo x, was the sportback and the sst - needed a ride for the new puppy and also a car that the missus could drive as well, so after an extensive search, the ralliart was the one
stage 1 - volk ce28n 18x9.5 +28, racing logic coilvers and flaring the wheel arches
first thing was the pure pizza cutter spec offset fail and the boat like handling, so straight from the dealer to wheelworx to get everything to fit - a bit of love was required, ok lots - if you plan on fitting rims with a similar spec, be prepared to have your rears worked over pretty hard - twas about 12-15mm of flaring and you'll need to take it to a body shop after to smooth out the warps and get it re-painted. the fronts had a slight roll. if i had my time again, i may have gone for 9 +36 for the ease of installation, but it was an offer i couldn't refuse on the rims and the end result was even better that i could have ever imagined - the final look / stance was worth all the hassles!!
well, here are some pics of the build
the rims straight after the work by extensive wheel services - they were originally bronze, but loved the time attack look, so got them re-painted (with a clear coat over the top)
once installed, they did stick out like dogs *****!
showing the tough road ahead!
racing logic vs stock
installed (almost - waiting on the sway bar bracket to arrive)
all installed, flared and raring to go!!
stage 2 (power up) and 3 (big brake kit) have been ordered and will be installed in several weeks time - stay tuned!!
summary of updates from throughout the thread
BBK
XB Kit (3" SS exhaust with custom quad tips, ralliart drop in filter and ecutek tune - 171kw@w up from 142kw base reading)
Philips HID lights installed
Promo shoot
Article on gearbox magazine
http://mitsubishi.gearboxmagazine.co...back-ralliart/
Autosalon 2010
Dyno run with the metal evo x bov (174kw@w)
Hankook z221 semi slicks (dropped 3.5 sec from my previous pb)
Evo X intercooler, hard piping kit, 100 cell race cat and retune (185kw@w)
Braid Rims (for track - 18x8.0 +36)
CBRD RAD turbo, grimspeed 3 port and replaced the SST oil
AEM intake
Last edited by billyboy1; Oct 22, 2012 at 10:05 PM. Reason: edited with a summary so far
Old Oct 19, 2009, 05:06 PM
RA173's Avatar
great job so far!
Old Oct 19, 2009, 06:26 PM
awilli1715k's Avatar
nice wheels
Old Oct 19, 2009, 06:46 PM
JHizzle's Avatar
looks sweet dude..2 questions
how much work had to be done on the rear fenders and if any on the front ones?
did you have to play around with the chamber?
Old Oct 19, 2009, 08:23 PM
billyboy1's Avatar
yep! the rears needed the most work - flared about 12-15mm and the fronts just a slight roll. bearing in mind, I'm running a fair bit of -ve camber about 2 deg and am using streched tyres 235 40. if you are keen on running this spec, allow a bit for bodyshop work to the rears
Old Oct 20, 2009, 03:27 PM
Bo0yaka's Avatar
Your car is looking hella sexy
Is that mivec badge on the fenders factory ?
Old Oct 20, 2009, 05:06 PM
billyboy1's Avatar
yep - must be an aussie thing then
Old Oct 20, 2009, 06:56 PM
GST Motorsports's Avatar
Looks nice.
Wheels and suspension really "wakes up" the looks of the RA's, just like the Evo 10.
All the lines and curves make more sense after.
- Bryan
Old Oct 20, 2009, 08:19 PM
evoxkrazy's Avatar
lookin gooood!!!!!!!!
Old Oct 21, 2009, 07:56 AM
jazket's Avatar
reaaaaaaaaaaaallly nice, nicest Sportback I've seen so far, and definitively liking it!
Old Oct 21, 2009, 08:23 AM
Ricekiller81's Avatar
That **** looks HOOOOOOOOOOTTTTTTTTTTTTTTTT!!!!!!!!!!!! All he did was Wheels and Suspention SICKKKKK!!!!!!
Old Oct 21, 2009, 08:29 AM
juzdyn's Avatar
very nice keep it up
Old Oct 21, 2009, 08:50 AM
Fizz Autosports's Avatar
WoW! Very sexy!
Good job!
Old Oct 21, 2009, 04:06 PM
billyboy1's Avatar
thanks guys it's amazing what the difference has been from stock from just coilovers and wheels!
Old Oct 21, 2009, 06:22 PM
boondoc's Avatar
Once again i say ****in sick.
Quick Reply: Ralliart Revitalization - my sportback build up
