AEM EMS Get tuning help for your AEM EMS system.
Infinty 8h=no A/C*Help PLZ*
Old Jun 17, 2016, 01:27 PM
BTR
BTR's Avatar
I switched over the infinity 8h back in January and last week I went to turn on my A/C and nothing. After testing all the fuses and relays I tried to tap on the compressor while the car was running but still nothing. I then ran a 12v wire to the compressor and the compressor turned on. After that I knew the infinity was not turning on the A/C. I started to read up about infinity and come to find out the 8h dose not support A/C. Is anyone running 8h with working A/C; how did you wire it up?
Thanks
Old Jun 18, 2016, 08:54 PM
TheBoz's Avatar
Do you have an open lowside or highside output?
Old Jun 18, 2016, 08:56 PM
TheBoz's Avatar
Also call aem they are very good over the phone, you can also post to the aem forums they normally respond in 1-24 hours. Most of my questions get answered within 2-3 hours, they are in California.
Old Jun 19, 2016, 08:53 AM
BTR
BTR's Avatar
Thanks for the help, I will have to check but I think I have a highside open.
Old Jun 20, 2016, 04:44 AM
itzwolf's Avatar
When running the smaller Infinity boxes on Evo's you have to use the Infinity-6 if you want to retain A/C. This is because LS6 (Pin 20 / AC Compressor Clutch Relay) is assigned to Injector7 as an available injector output.
You also lose the CEL light and Clutch switch on the 8h box. More details can be found at the top of page 6 of the below PDF:
30-3511 2003-2005 Mitsubishi EVO 8 INFINITY-6/8H* PnP ADAPTER HARNESS
Old Jun 23, 2016, 09:56 AM
BTR
BTR's Avatar
Thank you for the info.
Sammora
10
May 29, 2011 09:23 AM
mogace
Sep 4, 2010 10:49 PM
Jin4g63
Sep 12, 2005 10:23 PM
MitsuJoe
Oct 26, 2004 02:35 PM
MitsuJoe
Oct 25, 2004 07:54 AM
Quick Reply: Infinty 8h=no A/C*Help PLZ*
