Stage 1 low boost pressure
Old Nov 23, 2014, 10:08 PM
wallie123's Avatar
iIm currently use stage1 +sf ACN91 v403 and the highest peak psi has been 13.5. the map says i should peak at 23.5 psi. anyone know how to fix this?
Old Jan 23, 2015, 11:59 PM
wallie123's Avatar
anyone?
Old Jan 27, 2015, 12:11 PM
0uch.!'s Avatar
Originally Posted by wallie123
anyone?
You have 3port solenoid or somthing to boost control ?
Old Jan 29, 2015, 11:38 AM
D4MNIT's Avatar
anyone?
Could be a number of reasons that you are not achieving the target boost values. I would suggest that you attempt 2 or 3 third gear pull's again and log each run separately, from there you will be able to review the data from the car. Once you have that data you can then post it up and people can review the actual logs and perhaps provide some insight for you; a simple image of the Cobb interface, shows us what you saw, but not what actually occurred.
Old Oct 7, 2015, 09:03 AM
lmanluis123's Avatar
I know it has been a while but I was wondering if OP ever found anything out. Im curious to know as im having the same issue.
Old Oct 7, 2015, 01:50 PM
AngryEvo's Avatar
As far as I know you should only hit peak boost in 3rd and 4th. I might be wrong but I know the values are different in 1-2. Not sure if a boost controller would help fix that?
Double check all of your hoses and connections for leaks.
Old Jan 28, 2016, 11:11 AM
Julian Pierre's Avatar
You should be hitting peak boost in all gears not just 3rd and 4th. I would uninstall and install AP again. Then reflash map
Frasch
Oct 13, 2016 08:22 AM
hiboost2.0
16
Jan 2, 2014 08:10 AM
SoCalRedLine
Jun 19, 2013 09:40 AM
Bullett
North Texas Evo Club (NTEC)
18
Feb 26, 2012 05:39 PM
Show Off
Feb 25, 2008 10:52 AM
Quick Reply: Stage 1 low boost pressure
