Other 16" wheels that will fit Evo
Old Jun 16, 2011, 11:32 AM
  #31
rodent's Avatar
Originally Posted by dsmfan95
What about a 16x8 Slipstream with a 20+ offset?
If I do a 16" Hooser QTP setup, I really would like 16x8" wheels.
They only make that size in 4x100 BP and it would stick out 18mm more which is too much for those tires.
http://www.rotawheels.com/wheels.asp?wheelid=40
16x8 = usually means more weight excluding the FD wheels. For drag racing, I don't see any advantage for an 8" wide wheel.
Old Jun 16, 2011, 05:51 PM
  #32
dsmfan95's Avatar
Oops, sorry I thought I saw a 5x114.3.
I've talked to many sport compact people and they say to try to run the rim the same width as the tire. This maximizes the contact patch. I saw this on a friends FWD car, he was running a 15x7 on a 26x8" slick and after a pass, the contact patch was only about 6" across the slick, leaving an inch on each side untouched.
Old Jun 16, 2011, 09:06 PM
  #33
rodent's Avatar
If the patch is too narrow then the air pressure is to too much. Hoosier suggest 6"-8" width so 7" is in the proper range plus the QTP is pretty square. I will double check though after I get them mounted.
If you can find a super light (less than 15lbs) 8" wheel that will fit without spacers let me know and I will switch.
Old Jun 16, 2011, 09:23 PM
  #34
Wheatley's Avatar
Thanks to whoever did the footwork on the rpf1 +25 fitting without spacers! I have a set of rx7 wheels and spacers on the front that I was going to run but I have small brakes now and cant wait to ditch the spacers!
Old Jun 16, 2011, 09:27 PM
  #35
mrboost05's Avatar
they do make slips is 16x8 for 5x114 i had a set on my integra
Old Jun 16, 2011, 11:01 PM
  #36
rodent's Avatar
Nice! Shouldn't have an issue with the small brakes. Be sure to order them now since they will take awhile to get to the US.
I never said they didn't make the 16x8 5x114. I was only referring to the 16x8 with +20 offset. I bet you had the +40 or +48 wheels.
Old Jun 17, 2011, 08:52 AM
  #37
PATRICK B.'s Avatar
I believe "FILIN" from Europe has been running them on his drag evo for a couple years now if you search his SN you should be able to find a few vids of them.
Sorry i can't remember his exact set-up
Old Jun 17, 2011, 10:05 AM
  #38
Wheatley's Avatar
Thanks Pat! I just found a pic, It doesn't say what offset but the +25 should work perfectly. I was just about to cut the studs out of my spacers but if I can sell the rx7 wheels and spacers and drop a few lbs its a minor expense to buy some rpf1s
Old Jun 17, 2011, 10:32 AM
  #39
rodent's Avatar
Those looks great! Yep, +25 should be exactly where the stock Evo wheels are on the outside. You can also see that the hub area goes deep providing more room for brakes. Too bad they hit the stock Brembos on the very top.
I noticed the RPF1 also comes with the alum air stem which should meet NHRA rules. When you get the +25 wheels, can you weigh one and let us know. I think the deeper hubs like the +25 have a tad more material in the center.
Old Jun 17, 2011, 10:45 AM
  #40
dsmfan95's Avatar
I will be sure to post up results if I find anything!
I have a set of motorcycle slicks and rims that I have never used, but honestly I'm kind of weary of them. I'd like to get a 16" rim with a meatier tire.
Old Jun 17, 2011, 11:21 AM
  #41
rodent's Avatar
Same here but I sold them last winter. I never used the moto slicks since I was concerned going over 140mph on them. For a thin tire, they hook great but have a very thin sidewall and aren't rated for the Evo's weight. It took about 100 lbs of air pressure to get them to pop that last bead. I always wondered if that hurts the integrity of the tire. I did like 13lb moto tire weight compared to my QTP's which are 16lbs.
Old Jun 20, 2011, 12:47 PM
  #42
rodent's Avatar
I think I have the worst luck...
16x7 +40 Rota Slilpstreams HIT with a 20mm spacer, front of caliper close to where the Brembo logo is. 21mm or 22mm would be required despite what was posted in the original Rota thread by someone else.
Also my studs are longer than 20mm and hit the Rota wheel with the bolt on spacers. Pass through spacers with the ARP 3" studs would be a better choice. Or you could grind down the studs to 20mm length.
BTW- Out of the box, the wheels weigh 13.75lbs each.
Edit: Just ordered 22mm wheel spacers on ebay for $75. These should work for the Slipstream and FD wheels.
Old Jun 28, 2011, 07:42 AM
  #43
rodent's Avatar
Got my longer ARP studs and 22mm spacers. Slipstreams now fit nicely on the front and have close to 2mm of space between the wheel and caliper. Stick on wheel weights need to be very close to the spokes otherwise they will hit the caliper.
After I took out the studs from the bolt on spacers and made them pass through, they only weigh 1.25 lbs.
Much happier with these compared to the FD wheels. They seem to fit better and are lighter.
I'll try to take some pics after the rears are finished.
Old Jun 28, 2011, 10:44 AM
  #44
dsmfan95's Avatar
Can't wait for the pictures. Do the tires stick out past the fender any?
Old Jun 28, 2011, 01:40 PM
  #45
rodent's Avatar
They don't stick out at all. Looks pretty good. I'll try to take some pics soon.
Quick Reply: Other 16" wheels that will fit Evo
