Omni 4 bar and aem wideband logging
Old May 16, 2016, 07:30 PM
Ta/Fc1383's Avatar
So I'm just getting started with this whole open ecu tuning stuff. It's been several months of reading and searching online, also watching any tuning tutorials on youtube that i could find. I decided to try and tack a hack at setting up my ecu to log boost with the omni 4 bar and my afr with my wideband. I think i successfully accomplised that but in the process i made a mistake. I accidentally put the wire from the w/b to pin 77 instead of pin 75. Pin 77 is for fuel tank temp sensor curcuit. Im getting code p0183 for fuel tank sensor high input. I swapped the wires around once i realized what i had done and now I'm still getting the code on start up. I'm not sure where to go from here.
Old May 16, 2016, 07:31 PM
05EV08's Avatar
Reset the ECU by pulling your negative terminal and wait like 5 minutes.
Old May 16, 2016, 07:54 PM
Ta/Fc1383's Avatar
Is that the same as clearing the code with evo scan? Also should i disconnect both positive and negative cables and touch them together like you use to have to do in the older cars?
Old May 16, 2016, 08:19 PM
Ta/Fc1383's Avatar
Disconnected pos and neg battery cables. Didn't touch them together. I just let them sit there. The code was gone after i reconnected the battery cables. I start the car up amd just a couple seconds later the code comes back.
05EV08's Avatar
No it's different. I would not do that. Just keep it disconnected for a bit and give it a try.
Old May 16, 2016, 08:38 PM
Ta/Fc1383's Avatar
I did as you suggested. It didn't seem to make a difference. The code still came back. I then reverted back to the rom version i had without the omni map sensor and also reinstalled the stock map sensor. Cleared the code, started the car idled a couple seconds and the code came back just as before.
Old May 16, 2016, 08:55 PM
Ta/Fc1383's Avatar
I went one step further and I disconnected my w\b from the ecu and plugged back in the original wire. Reflashed the ecu to my last know good running rom version and ended with the same result. I hope i didn't fry something in the ECU by connecting my w/b to the wrong pin.
xPRimNT
157
Dec 26, 2018 08:09 AM
TigOLDBiTTies
Oct 27, 2013 07:20 PM
rr06rs
Jun 13, 2012 07:01 PM
magyar86
Nov 23, 2010 08:12 AM
gazza19800
Aug 12, 2010 12:42 PM
Quick Reply: Omni 4 bar and aem wideband logging
