EvoScan v2.6 And New EvoScan GPS/Logger/Reflashing Touchscreen Review
#47
ok sweet, I'll work on it now,
1) Hotkeys are now re-written using different windows apis, and now works in XP, Vista and Vista64bit
2) Vista64bit Zeros problem turned out to be my obfuscation compiler, I changed to a different obfuscator compiler product but still the issue is there I'll get to the bottom of it tonight.
3) HP/TQ wont have any enhancements to it until EvoScan v2.7 which I will rewrite the whole HP/TQ section. I am currently focusing on reflashing and maptracer for v2.6
4) Priority, i had the same issue when I tested it too, I guess I should just do one thing at a time, before moving on to the next
#50
Thanks
#53
possibly a very simple answer, however im very new to the evoscan software. is it possible when veiwing a log either in real time or playback to adjust the resolution so to speak eg if im only interested in seeing the coolant temp variations between say 60-70 degrees rather than the full scale of 0- max? if this is possible how is it done. thanks in advance
#54
EvoScan v2.6 beta5
link updated on Post#1
new Hotkeys programmed.
new Priority programmed.
new Samples per Second programmed.
dlls now built into the exe (please delete these two files from the directory as they are built into the exe now): FTChipIDNet.dll and TrackBar.dll
I am currently working on these new data items for EvoScan:
GPS_Latitude
GPS_Longitude
GPS_SatelliteTime
GPS_Speed
GPS_Bearing
GPS_HDOP
GPS_Latitude
GPS_Longitude
GPS_SatelliteTime
GPS_Speed
GPS_Bearing
GPS_HDOP
#55
Press Ctrl-E to edit a dataitem to set each item logging priority, during periods inactivity it will log to the csv the last known value. A value of 10 will mean it will only update every 10 loops. a value of 0 or 1 will mean it will update every 1 loop.
#58
can i ask 2 possibly very dumb questions, is there an appropriate thread for evoscan noobs to ask the silly questions like how to change guage layouts so the only contain data items i want rather then the default etc. and also i have tried downloading the latest version but it wont work when i click on the icon it displays "Could not find a part of the path 'C:\Documents and Settings\Owner\Desktop\SavedSettings\EvoScan.xml'. " it will then open the evoscan software but there are no data items populated??? once again sorry for asking what may seem like stupid questions but im trying to learn it to get the most out of it.
once last question does your latest cable support the ayc abs functions without needing the mod described on your homepage if it cant whats it worth for a cable that can
regards and awesome product by the way
