The DTC Disable thread (P1235, P1241, P1238, etc)
#541
hi, help please
i tuned for first time a lancer Gt Cvt ecu id 52180008 with turbo kit of evo x and i have the error p1235 and p1241
Please help for eraser this DTC
And the other problem is my definition pass to load of 100 to 260, and between no have data for change.
this car is good run but with the error is limp mode
please
my email is rogerpizarro@gmail.com
please
ECU from Evo installed ?
#543
Hey has anyone come up with a way to disable P04443 as well as P2128 on 52680022. I've installed a evo x motor in a 2008 lancer gts using 08 evo x ecu. these are the only 2 codes I have. I've switched pedal sensors out for known working one and verified all wiring to ecu is correct.
#547
I seem to recall this will disable the rear o2 sensor's heater circuit as well... which apparently isn't healthy for the sensor if it's still fitted.
If your sensor is still present and you care about it, plan B would probably be to try one of those o2 "extender" fittings, which move the sensor back and away from the airflow.
If any of this is wide of the mark, folks, please feel free to offer corrections!
Rich
Rich
#549
greetings masters,
i just wanted to ask for your help to disable my current dtc. i flashed an Evo x Rom on my stock Turbo Lancer 2.0L 4B11. my car starts and runs just needs a tuning but my concern now is maybe you can help me disables these dtc that pops up. i've been reading for weeks now about disabling these dtc.
i'm willing to donate anything...
i've been messaging master tephra about my concerns but his inbox is full.
DTC to disable:
1. P0098
2. P0183
3. P0365
4. P0441
5. P0106
6. P0452
7. P0243
8. P0069
i hope you can help me guys
cheers,
DTC to disable:
1. P0098
2. P0183
3. P0365
4. P0441
5. P0106
6. P0452
7. P0243
8. P0069
cheers,
