launch maps
Old Jul 4, 2013, 08:31 PM
  #241
Benja's Avatar
Copy the 5500 timing line into the 6000 and then smooth it on either side and see how you go.
You'll need to smooth your fuel also otherwise you'll bog down.
Old Jul 4, 2013, 08:38 PM
  #242
hiboost2.0's Avatar
Originally Posted by andru38
Hello everyone!
Help me set up lunch!
I can not make a wheel slippage. Lunch at 5450 and 1psi, when dropping the clutch pedal car makes one revolution of the wheel and falls into a pit.
Evo8, 2.0 Tomey 7960, wheels 235/45/17
tefra7
What am I doing wrong?
Does it knock at all when you let go of the clutch? If so then you need to ease back into your main map. You can't have areas where it goes from like -1* of timing to 7* of timing in the next cell. It needs to be smooth. If that's not the case it sounds like you're letting the clutch out too quickly.
Old Jul 4, 2013, 09:11 PM
  #243
211Ratsbud's Avatar
Yes also smooth timing from idle to launch maps. Set your tps threshold to something just off idle tps. Boost builds this way as you press the throttle
Old Jul 4, 2013, 11:16 PM
  #244
andru38's Avatar
Thanks, I'll try.
now began to rain, I tried to 6000, uuh well went dry tarmac waiting
Old Jul 4, 2013, 11:51 PM
  #245
andru38's Avatar
Guys! Do not get me correct, please help.
Old Jul 5, 2013, 12:21 AM
  #246
andru38's Avatar
I would like to turn the wheels, all four .....
Old Jul 5, 2013, 06:38 PM
  #247
andru38's Avatar
friends, help please, correct cards
Old Jul 6, 2013, 10:44 PM
  #248
andru38's Avatar
well somebody to me help!
Old Jul 6, 2013, 11:09 PM
  #249
mchristian's Avatar
You really are Russian, aren't you?!?! Lol
What is your timing and fuel settings at 5450 rpm? Are you sure you turned on the launch maps?
Old Jul 7, 2013, 01:26 AM
  #250
andru38's Avatar
yes I Russian! ! what's the problem?! 6000 ignition-5 fuel 9, and I am sure that the lunch joins
Old Jul 22, 2013, 04:41 AM
  #251
project_skyline's Avatar
Has anyone had to do anything weird with mivec for launch maps to work good or no?
Old Jul 28, 2013, 03:51 PM
  #252
CDrinkH2O's Avatar
smooth transitions
Your map transitions need to be smoother and the launch area bigger. Try this.
Old Sep 23, 2013, 08:27 AM
  #253
Lion_Sam's Avatar
Originally Posted by Raptord
You shouldn't need launch maps on a stock turbo
If I've Arashi Evo IX turbo, it will be bad for it too?
Because it's like hitting with a hammer on the impeller...
Old Sep 23, 2013, 02:59 PM
  #254
211Ratsbud's Avatar
7-10 on a stock turbo would usually spin and grab 90% of tires. On slicks with a little better traction you can get away with a little more.
I've tuned up to 20-22 no knock and lemme tell ya that is pointless if you're trying to 60' and use your clutch more than a couple times.
Old May 20, 2014, 10:03 PM
  #255
sgambino92's Avatar
So I'm gonna open this thread back up. Recently got into messing around with EcuFlash and I'm just curious to how everyone thinks my launch maps look. This was a pretty helpful thread so why not bring it back up!
Builds about 12psi
2-Step: 5812 rpms
TPS Threshold:90%
3076R
FIC950cc
SparkTech COP non cdi
etc...
Just curious to what everyone has to say. Thanks!
Quick Reply: launch maps
