TephraXMOD V1
Old Oct 3, 2015, 05:44 AM
  #901
Matruco3's Avatar
No love for 08 Evo X?
I am trying to upgrade to the latest and greatest 08 stock map but I cant seem to find the definitions anywhere.
Can anyone share a tephra modded 52680024 stock map and definition? (52680124)
Old Oct 25, 2015, 10:29 AM
  #902
Hiboost's Avatar
So I prepaid for Tephra V2 but been getting along ok with Tephra V1 for now until the MR's are supported with the latest updates. Benchflashing my 2011 down to a 2010 has been trouble free.
I have a customer wanting map switching between pump gas and E85, can I downflash his 2014 MR down to a 2010 MR Tephra V1 rom without having to benchflash? I can't remember if I read anyone doing this from the latest version of ECUFlash without pulling the ECU from the car on a 2014 or not. I can confirm that just last week I flashed a 2011 down to 2010 in the car without any issues.
Old Oct 25, 2015, 10:37 AM
  #903
Hiboost's Avatar
I guess I should have looked at this thread:
https://www.evolutionm.net/forums/ec...rom-evo-x.html
Only question is that I believe that the latest ECUFlash updates might allow more in car flashing without bench flashing which I will have to test.
UPDATE LIST
Known crossover ROMs-
USDM 2010-2011 GSR interchange
USDM 2010-2011 MR interchange
USDM 2010-2011 GSR TephraMod ROM interchange
USDM 2010-2011 MR TephraMod ROM interchange
USDM 2012-2014 GSR interchange
USDM 2012-2014 MR interchange
Known non-crossover ROMs with convential flash method-
USDM 2012 MR will not backdate
USDM 2012 GSR will not backdate
Known crossover ROMs with bench flashing-
All years and models currently benchflash to each other and MR ECU's can be turned into GSR ECU's
Old Dec 13, 2015, 10:15 AM
  #904
charlie.tunah's Avatar
Are Tephraxmod roms known to be compatible with Windows 10? I am trying to help a buddy get set up with v1 until the SST is supported in v3 and everything works fine on my computer, but his shows all tephra roms as unknown rom image. We've put all the necessary files in the correct places.
thanks
Old Dec 13, 2015, 12:06 PM
  #905
mufasa39's Avatar
missing files
thanks
Simple issue, There are maps and XML files that missing(you have to put in) on his version
of software and make and model of car, 2 files required. Make sure they are in the right place for the software to link it. Its been awhile since I had to do this
Old Dec 13, 2015, 03:34 PM
  #906
Thanks for the response. You are correct.
He finally figured it out after he left today. He had originally told ECUflash to look at a custom folder for the defs and was working properly for his stock rom because he put some goldenevo xmls in there. It held that setting through multiple uninstalls/installs of 1.44 and 1.42. I didn't think it would have kept custom settings and overlooked it.
Old Dec 17, 2015, 10:53 PM
  #907
lexa609's Avatar
And how to enable launch control?
stationary rev limiter change , but launch control is not working.
Old Jan 12, 2016, 11:07 AM
  #908
tjac357's Avatar
Question,
I have a 2010 SE. When I go to pull the rom it says it's an unknown image. I've tuned multiple 08 GSRs and tons of VIIIs/IXs. I'm sure my files are all up to date. Does anyone know if the special editions have a different rom loaded onto them? I don't like just flashing a rom onto a car without having the factory file just in case something goes wrong in the flash. Especially since it's my daily.
Thanks guys
Old Jan 12, 2016, 12:46 PM
  #909
RazorLab's Avatar
Received 1,038 Likes on 760 Posts
Originally Posted by tjac357
Question,
Thanks guys
No, the SE's have the same rom as the 2010 MR.
If you are looking for the factory ROM: http://norcalmotorsports.org/users/b...ch/ROMs/Evo10/
Old Feb 8, 2016, 05:12 PM
  #910
Jaraxle's Avatar
sub'd
Old Mar 25, 2017, 07:17 PM
  #911
Jaraxle's Avatar
I am ready to ask some dumb questions. I have been using Cobb accesstuner since '12 when I bought the car and have literally tuned/flashed my ECU hundreds of times (around 200). Since I am thinking of moving to E85, Tephra is the only true answer for anyone looking to maintain control of their ECU. And this is where my knowledge nose-dives.
I don't see 2012 USDM MR being listed as supported (TephraXMod v3) but 2013-2015 MR is supported.
Previous thread above shows:
Does this indicate that I can flash my ECU with a 2014 targeted v3 tune because it is a "crossover ROM" ?
It looks like 2011 and 2012 are the only years not supported for the MR for build years 2008 through 2015. I am confused.
I want to switch over all my maps, and start taking advantage of the increase in control with evoscan/tephra.
Thanks!
~Jaraxle
Old Jul 21, 2017, 11:42 AM
  #912
Sterbo's Avatar
Someone has the definition for this:
https://drive.google.com/file/d/0B8q...ew?usp=sharing
It should be here x sst edm 2009 53050017 (just updated in Mitsu dealership)
edit
Old Jul 22, 2017, 01:13 PM
  #913
lexa609's Avatar
Never met such a problem ?
If you turn off the ignition when the air-conditioning and engine cooling fan , the engine stops and the fans continue to work without the ignition.
The problem is not always the case.
If to throw off the terminal of the battery then the fans stop.Or if you start the engine and turn the air con off it also stops.
etax changed.
relay changed
Maybe it's in the firmware ?
rom id 53040010
Old Jul 22, 2017, 09:36 PM
  #914
richardjh's Avatar
etax changed.
relay changed
rom id 53040010
Mine has done exactly this - even before using any ROM patches/tunes/mods.
It's odd, but definitely seems to be Mitsubishi-intended behaviour. It's not a fault or a bug.
Rich
Old Jul 24, 2017, 06:46 AM
  #915
Sterbo's Avatar
etax changed.
relay changed
rom id 53040010
I think it's normal, the fans remain on after the power off if the ECU detects that the temp is high (within limits), after a few minutes they turn off alone ... I happened in special cases where there was very hot all 'external.
Quick Reply: TephraXMOD V1
