ROM disassembly as raw text file
Old Jun 18, 2015, 10:27 PM
  #226
franzcars's Avatar
Originally Posted by richardjh
That's pretty cool...
Rich
Thanks! I couldn't have done it without looking at your patch and all the info you put in this thread!
I have an idea how to do the stationary rev limiter and how to better do the normal rev limiter control.
If all goes well i'll be releasing it to the public and I'll post a binutils objdump with comments so other can learn as I did
Old Jun 19, 2015, 10:25 PM
  #227
franzcars's Avatar
Patch should be good to go, just need some others to test and see how it works.
Here's a quick video Demo of it in action
Old Jun 19, 2015, 10:57 PM
  #228
richardjh's Avatar
Awesome patch info. What ROM ID is this in? So I can find the exact place you've put the patch-to-call-0xd6000 code...
Rich
Old Jun 19, 2015, 11:05 PM
  #229
franzcars's Avatar
I'm using Rom# 59580004. The easiest way to find where I BL to is look at the MUT table for MUT2D, That's the dwell RAM address. If you put that address through your Calculator posted earlier and add 1, then search the number you'll find it where you need to branch just above it.
So in my case MUT2D is 80ab61, which when put in your calculator it gives you the value -5279, so add 1 to it and you get -5280. When you search that value or the hex you find this
Code:
   217d4:	e0 05 85 aa 	ld24 r0,#0x585aa	-Loads the Data from the Dwell table
   217d8:	fe 00 b2 74 	bl 0x4e1a8		-Interpolates
   217dc:	50 44 f0 00 	slli r0,#0x4 || nop	-Moves the data
   217e0:	fe 02 d2 08 	bl 0xd6000		//Normally where it'd store the data, branches to my subroutine
   217e4:	80 c0 ff ff 	and3 r0,r0,#0xffff
   217e8:	50 04 f0 00 	srli r0,#0x4 || nop
   217ec:	a0 2d eb 60 	sth r0,@(-5280,fp)
So it should be very similar in other roms
Old Jun 20, 2015, 07:33 AM
  #230
richardjh's Avatar
Sorry if this is a dumb question - I'm rusty - but shouldn't those register "pop from stack" ops be in reverse order to the register "push onto stack" ops?
Otherwise, what will go into the patch function in r0 will come back out in r8...? etc.
Rich
Old Jun 20, 2015, 08:05 AM
  #231
franzcars's Avatar
Rich
Good point, this was my first time ever doing assembly and I had no idea that you had to keep it lined up like that. I will fix it in my patch asap. Thanks!
Old Jun 20, 2015, 08:39 AM
  #232
richardjh's Avatar
Yeah, if you push registers onto the stack in order 0/1/2/3/4/5/6/7/8, your "pop" off the stack at the other end should be in order 8/7/6/5/4/3/2/1/0.
Your first time doing assembler looks a whole load better than mine, I'll say that!
Rich
Old Jun 20, 2015, 12:11 PM
  #233
franzcars's Avatar
Totally makes since now, deffently explained why the dwell in Evo scan looked weird since it was loading a different value then it was supposed to
Old Jun 20, 2015, 07:12 PM
  #234
richardjh's Avatar
What the push/pop order issue would have done was to mess up this bit:
Code:
If that's what you mean, then yes. r0 would come out of the patch with whatever value was in r8.
I've found the same bit of code in my ROM, and it looks like the lines above load data into a RAM location that isn't subsequently used by anything else... it's likely there for diagnostic purposes, so it can be watched.
And zooming out, nothing subsequent to the code in question cares about r0-r8 values... so no real-world impact in this particular case.
Old Jun 20, 2015, 07:44 PM
  #235
franzcars's Avatar
Yeah, I got very lucky that it was set up how it was, since my registers were not right, but that has now been fixed. Next question is, should I pop R0 back or leave it be? I think that if I pop it, it will show whatever Dwell would notmally be, not what it is. But If I dont pop it, I think it will show when the cut it enabled besides looking at that one ram address
Old Jun 21, 2015, 05:50 AM
  #236
richardjh's Avatar
Tough call. I started out leaning towards the option of preserving the original ECU value there (ie. push/pop r0), but then reconsidered... because if that value is there to show the actual value being used, perhaps it should do just that.
Rich
Old Dec 29, 2016, 09:07 PM
  #237
Dow Jhob's Avatar
I saw JAMC perform, just a couple of years ago... on the post-Coachella-reunion glory tour. William didn't attack Jim (or us) with his mike stand, the band was tight, and they played out the entire set... but they were brilliant nonetheless. That perfect sound just washed over us, and for a little while we were all young, stupid and happy again. All hail the Reid brothers. A-hey-hey-heeeey....
But back to the task at hand! I've got objdump updated with the missing M32R definitions, and I'm happy enough with its assembler output.
I've attached my current build. There's also a readme in there, plus a wee shell script to run the tool a bit more easily.
Yeah, I know Linux isn't normally a "provide-a-binary" kind of world. Everyone normally rolls their own. If requested, I can always bundle up the few source mods I made (required to add support for the M32R "bclr", "bset" and "btst" opcodes). You can then stuff around with a full binutils v2.9.1 package download... if that floats your boat.
The attachment is tar.gz style. As it was 200KB and an EvoM-unspecified file type, I renamed it in a pleasantly dodgy way. Just rename it right back.
If you give it a try, let me know how it goes. Sure looks good on my Ubuntu laptop... and no more "*unknown*" opcodes...
Code:
    b974:    a0 bd c5 f0     lduh r0,@(-14864,fp)
    b978:    01 f0 7c 04     btst #0x1,r0 -> bc 0xb988
    b97c:    e4 80 07 00     ld24 r4,#0x800700
    b980:    a5 74 00 00     bclr #0x5,@(0,r4)
    b984:    7f 03 f0 00     bra 0xb990 || nop
    b988:    e4 80 07 00     ld24 r4,#0x800700
    b98c:    a5 64 00 00     bset #0x5,@(0,r4)
Sweet!
Rich
please give src your objdump fix, your native objdump dosnt work in cygwin
Old Dec 30, 2016, 07:17 PM
  #238
richardjh's Avatar
Here you go!
This was based on the binutils version 2.9.1, which is ancient history these days.
My source edits are commented (look for "RJH"). You can also just download the old 2.9.1 sources and diff these three source files against their originals... and make the same edits in the latest version of binutils objdump.
Have fun with it!
Rich
File Type: zip
Old Dec 30, 2016, 07:25 PM
  #239
richardjh's Avatar
If I'm reading their source correctly, the current version of binutils (v2.27) has those instructions supported now, so there's honestly no need to go messing around with ancient v2.9 patches.
In their m32r-opc.h file, they have...
, M32R_INSN_MULWU1, M32R_INSN_MACLH1, M32R_INSN_SC, M32R_INSN_SNC
, M32R_INSN_CLRPSW, M32R_INSN_SETPSW, M32R_INSN_BSET, M32R_INSN_BCLR
, M32R_INSN_BTST
} CGEN_INSN_TYPE;
Those are the ones I had to add myself, way back in the neolithic age...
, M32R_INSN_TRAP, M32R_INSN_UNLOCK, M32R_INSN_PUSH, M32R_INSN_POP
, M32R_INSN_BTST /* RJH - Added new instruction July 8, 2011 */
, M32R_INSN_BCLR /* RJH - Added new instruction July 8, 2011 */
, M32R_INSN_BSET /* RJH - Added new instruction July 8, 2011 */
, M32R_INSN_MAX
} CGEN_INSN_TYPE;
So just go with the latest stock code. Have a great 2017!
Rich
Old Dec 31, 2016, 09:07 AM
  #240
Dow Jhob's Avatar
thank, happy new year
Quick Reply: ROM disassembly as raw text file
