Requested Torque/Throttle Ramp Rate Tables
Old Oct 18, 2011, 08:06 AM
  #31
tephra's Avatar
Originally Posted by Bernhard
I drive with changed ramp rate maps since about 2 months now and I am quite sure that the cruise control behaves different than before.
Can anyone confirm this?
Can you elaborate?
As far as I know the cruise system uses another code path for TPS decisions.
Old Oct 18, 2011, 03:10 PM
  #32
itzwolf's Avatar
Originally Posted by RS200Z
If you are using Golden's definition, you can add the following into 56890009.XML as 56890010 inherit from that. Otherwise replace the scaling="Percent255" with just "Percent" as per Tephra's post #1.
Code:
  <table name="Requested Torque Ramp Rate - SST Normal Mode" category="Torque" address="5f853" type="3D" swapxy="true" scaling="Percent255">
    <table name="VehicleSpeed" address="62cea" type="X Axis" elements="6" scaling="VehicleSpeed"/>
  <table name="RevPerMPH" address="63088" type="Y Axis" elements="8" scaling="RPMPerMPH"/>
  </table>
  <table name="Requested Torque Ramp Rate - SST SPORT Mode" category="Torque" address="5f81b" type="3D" swapxy="true" scaling="Percent255">
  </table>
  <table name="Requested Torque Ramp Rate - SST S-SPORT Mode" category="Torque" address="5f7e3" type="3D" swapxy="true" scaling="Percent255">
  </table>
  <table name="Requested Torque Ramp Rate - 5MT" category="Torque" address="5f7ab" type="3D" swapxy="true" scaling="Percent255">
  </table>
Thanks!
So is it normal that the 5speed ROM has SST these maps as well? I just find it strange.
Old Oct 18, 2011, 03:29 PM
  #33
RazorLab's Avatar
Received 1,038 Likes on 760 Posts
Originally Posted by itzwolf
Thanks!
It's normal for Mitsubishi. They usually keep the tables but just turn on/off code paths.
Old Oct 18, 2011, 06:02 PM
  #34
itzwolf's Avatar
Gotcha. I guess it does make some sense and when compiling simply change variables for the platform the ROM is for...
Old Oct 19, 2011, 03:30 AM
  #35
Beeble's Avatar
Originally Posted by Jumperalex
So are you saying somewhere there is a way to change the behavior, predictably, of Auto-Normal? Because OMG I could love to tweak that to be a bit more agressive. I'd also like to tweak Auto-Sport to be a tad less agressive. They are just to ofar apart to be useful.
You can modify them quite successfully, yeah.
Make Normal a lot less doughy and crisper shifting , and you can dumb down Sport if you wish.
As Bryan said, it really changes the way the car drives when in Auto mode.
Old Oct 19, 2011, 11:21 AM
  #36
Golden's Avatar
The Ramp Rate's are set at 100% for Top Gear in GSR's. Look at the 48 row.
Are you having issues with cruise in lower gears?
Old Oct 20, 2011, 01:43 PM
  #37
NZEvox's Avatar
can anyone post it for a jdm sst 52370024 thanks :-)
Old Oct 30, 2011, 04:45 PM
  #38
AIK
AIK's Avatar
I have compared 53050009 and 12 (5f5c7 address) NORMAL tables.
They are identical.
Old Nov 4, 2011, 03:05 PM
  #39
4G63pride's Avatar
I want more crisp shifts. I hate the way it feels like it slips into each gear. Specially 1st to 2nd shift feels really sloppy.
Old Nov 4, 2011, 05:19 PM
  #40
chetrickerman's Avatar
do you have an MR?
Old Dec 25, 2011, 11:35 PM
  #41
nonschlont's Avatar
edit:
Old Dec 30, 2012, 03:13 PM
  #42
momostallion's Avatar
sorry to bring this thread up but is anyone playing with these tables anymore?
i believe i found the definitions for 58010005, if anyone can check my work that would be nice.
Old Dec 30, 2012, 03:52 PM
  #43
oh great, i just noticed these have already been defined for 5802*
well at least my addresses all match so that is some consolation.
and so it wasn't a complete time waste, here is Requested Torque Ramp Rate - 5MT for 58010005:
Code:
<scaling name="Percent" units="%" toexpr="x*100/255" frexpr="x*255/100" format="%.1f" min="0" max="100" inc="2" storagetype="uint8" endian="big"/>
<table name="Requested Torque Ramp Rate - 5MT" category="Torque" address="5f7cf" type="3D" swapxy="true" scaling="Percent">
	<table name="VehicleSpeed" address="62d54" type="X Axis" elements="6" scaling="VehicleSpeed"/>
	<table name="RevPerMPH" address="630f2" type="Y Axis" elements="8" scaling="RPMPerMPH"/>
  </table>
Old Apr 1, 2013, 04:10 PM
  #44
99EclipseGSX's Avatar
Anyone found these on the 59580004 '13 Evo X?
Old May 23, 2013, 10:17 PM
  #45
xBoostx's Avatar
I am interested as well.
So one would increase the cells that arent 100 percent till a desirable change is met?
Would it make for a crispier throttle?
Quick Reply: Requested Torque/Throttle Ramp Rate Tables
