boost control maps
boost control maps
I'd like to do a little boost tuning using my GM BCS. I've read some of the articles around the forum. but would like to see some real world settings from people running around 25-28 psi on E85 so that I can get an idea of where to start with my settings and to understand what the settings are when changed.
I'm on an EvoIX stock turbo, basic bolt ons, E85.
Thanks guys!
Thanks guys!
You'll probably end up with 100% WGDC @ 6k+ giving you approximately 20-21psi - that's all the stock EvoIX can at that RPM, airflow g/s calculated by ECU with MrFred's calculations being turned on will be 290-315g/s depending on the ambient temperature.
Anyway, starting with 60% WGDC across the board for your boost goals is normal and reasonable. Also you'll see that WGDC differs significantly by gears to get identical boost curve (once it spools up).
I think it is risky to run that kind of boost on a stock turbo.
Having a WGDC @ 100% >5500RPM means that you are running out of the compressor map (in english: you are killing your turbo)
Cheers.
Cheers.
i just installed my gm 3port. and i will say i am highly confused at the moment. lol i am running V7 and started tinkering with the "main map wastegate duty" and "boost desired engine load". at the current moment i just left the map how it is and did a pull. it went to 26ish and i left off. so i lowered the entire "BDEL" map to 50.0. did another pull, with same results... This is where i am confused. do i edit the "main map wastegate duty" and not the "BDEL"?
