New EVODROID7 EvoScan Android GPS/Logger/Reflashing CarPC Touchscreen Review
#1173
so, i'm interested... but not enough to read 80pgs of text LOL.
i have an Innovate WB and taktrix cable along with a subscription to Evo Scan that i've been using forever. is this going to work for me? i'd really like to not have to take my laptop in the car with me.. i'm tired of ruining USB plugs.
#1175
Hi guys,
I need a big help for two reasons:
1) I'd like to copy my Evoscan layout (https://www.evolutionm.net/forums/ev...-gauges-2.html) one of main reason I bought Evodroid.
I know there is the gauge designer but I can't use it without a base. If I can get pieces from Evoscan layout I can with patience build it again but from a scratch layout for me is impossible.
If it's easier I can accept a black screen with digits for useful parameters, like SST temp and so on.
2) I use the OpenPort2.0 that comes with a female 3.5 mm jack to plug my LC-2 signal.
I'd like to do it also for the 3.0DA so I have to buy a female 3.5mm jack port to wire to the side of my 3.0DA. Which pin I have to use?
Thanks a lot for help
#1176
Hi Guys, I need help...
Since I got my Evodroid 7 last year for my EVO X MR, I have only tried out a few times but never been able to get all the gauges or reading going on the standard gauge layout, only RPM, speed, throttle & battery is working but not the rest.
Anybody has any answer to it??? cheers.
#1177
Hi guys,
#1178
If you are looking for timing and inside the xml file is called LogReference="TimingAdv", in log reference row (inside GaugeDesigner) you have to write TimingAdv.
First thought
#1181
BTW, is anyone running it on Nexus 7 (1st gen: 1280x800) or other devices with same resolution?
#1182
has anyone though of trying something like an encore mini (http://www.toshiba.com/us/tablets/encore/mini) its 7inches and should be able to run native evoscan and fit in the double din... the only thing im questioning is the usb support since i think the connection is a microUBS and dont know if the drivers will support it.
I havent had much time to play around with the evodroid but my goal was/is to install it in the double din and set it up as a media center for my car. I planned to tether it to a hotspot for google maps and spotify and use an amp to power the speakers and sub.
on another side note..Hamish do you answer PMs anymore?
#1183
Interesting! I've read people using OTG USB cables to use USB devices with this tablet. So it looks promising. But I don't have evoscan, or windows 8.1, so I can't tell from experience.
#1184
I cannot for the life of me get RAX patch working for logging or gauge display for that matter. I've tried everything I can think of. I can get mode 23 but only a couple things, like the speedo, tach, knock, throttle, and battery. I need RAX for the logging though. If you could help that would be great. I've been talking to Hamish but I know he is just too busy and can't answer questions as quick as we would like. I think he has a great product here. He is only one man handling A LOT. So it's understandable. If you could help me that'd be awesome.
