Sponsored by:
Sponsored by: CARiD
Unable to set Evoscan gauges
Old Jul 2, 2014 | 04:32 AM
evoscan's Avatar
Silver Sponsor
You are also saving it under a different name that you didn't know about.. called Mio.xml. Make sure you are editing and saving the right one. Send me your Mio.xml template, and your datasettings xml file for your vehicle and I will check again.
Old Jul 2, 2014 | 05:17 AM
evoscan's Avatar
Silver Sponsor
Yep I saved the layout, and re-opened it.. the values still show perfectly as before. I am using the same vehicle datasettings.xml each time. You can see it here, I opened it again after saving and closing evoscan.
Old Jul 4, 2014 | 05:15 PM
evoscan's Avatar
Silver Sponsor
yep no problem here. I can't replicate the problem.
Old Jul 7, 2014 | 03:19 AM
evoscan's Avatar
Silver Sponsor
ok, I'll close this issue as resolved. It works perfectly during all my tests. send me an email with screenshots if you see anything that needs attention.
Cheers,
Hamish.
Old Jul 23, 2014 | 09:49 AM
Fede's Avatar
Dear Hamish,
thanks a lot for your help!I was really busy during this period so I couldn't read/reply as I should.
I'll test your solution as soon as possible.
I noticed that the problem (can we say "unsaved changes"?!?) affects also the name of the gauges inside the menu. "SST temp" was at the beginning "Battery voltage". I see the right name in the layout but inside the edit menu is always called "battery".
I can modify it in the same way as for scales settings?
Thanks again
Old Jul 29, 2014 | 02:24 PM
Fede's Avatar
I've tested, some updates under the same ticket, I'm not able to get it as it should.
Waiting for reply, thanks again.
Old Jul 30, 2014 | 03:11 AM
evoscan's Avatar
Silver Sponsor
Can you please send some screenshots to show you what you mean?
Old Jul 30, 2014 | 06:30 AM
Fede's Avatar
I've attached it yesterday with a new reply added inside my ticket
Old Jul 30, 2014 | 07:00 AM
Fede's Avatar
Added better description
Old Aug 17, 2014 | 01:31 AM
Fede's Avatar
I'd like to thank Hamish because now I can have my Evoscan working as I like!
He did a great job and also provided me a patch to help me see what and where I'm saving my layout.
This time I can't complain at all about the customer service because he did what it takes to get all properly working and by that, I'm not saying there was some sort of bug but that I wasn't able to make it work as I want to.
Old Aug 26, 2014 | 11:43 PM
Fede's Avatar
Now that all is working as I need to, I'd like to buy Evodroid, just waiting to get some infos from Evoscan staff.
Old Oct 20, 2014 | 06:42 AM
Fede's Avatar
Hi guys,
after my enthusiasm of having Evoscan working properly, I've bought Evodroid7 but I need some help. This time Evoscan support isn't as fast as my desire to have it working right.
I need to use my layout (see on top) in Evodroid but seems quite difficult?
Any idea that could help me?
Thanks a lot.
Old Oct 26, 2014 | 10:41 AM
Fede's Avatar
After a long teamviewer session with Hamish I can start working to my new layout!
Credits to him for support!
ant_turbo
Feb 10, 2017 11:41 AM
xPRimNT
239
Jun 2, 2016 10:40 PM
evo4mad
May 5, 2015 06:22 PM
johnnnyjeans
Oct 12, 2013 01:58 PM
