Sponsored by:
Sponsored by: CARiD
Unable to set Evoscan gauges
Old May 1, 2014 | 10:01 AM
Fede's Avatar
Angry Unable to set Evoscan gauges
Hi to all, I have an annoying problem I can't figure out by myself using gauges in Evoscan (V 2.9.0023).
I create my own style using an existing layout but it won't work. I'm able to save the layout I see (name of gauges, position and so on), also state and numeric indicator parameters. What I can't setup correctly is under "edit template" menu. I can change name of gauges, numeric indication options, scales etc then i press "apply", "finish" and I save changes.
Everytime I close Evoscan I can't have these parameters as saved and I have to do all again.
Someone can help me?
Thanks!
Old May 2, 2014 | 02:00 AM
Fede's Avatar
Help please!
Old May 2, 2014 | 04:00 AM
Johnr352's Avatar
I think you would have better luck under Electrical, Audio Security. Or even Show and shine. No luck on the manu website?
Old May 3, 2014 | 07:13 PM
ikt's Avatar
ikt
because Evoscan is broken. Certain parts of it just don't work and probably never will.
Welcome to the worst customer service of your life, too. As in, you're never going to get help. If you want to try, though, you can try here
Old May 4, 2014 | 11:34 PM
Fede's Avatar
Hi guys,
thanks for reply! I hope someone can figure it out for me (not hoping in the customer service though)!
Old May 5, 2014 | 09:59 AM
evoscan's Avatar
Silver Sponsor
Thanks!
Hi Fede, send us an email or support ticket, I see none from you yet, under the name "Fede"
Have you tried saving to the documents folder, the program files folder is locked down by microsoft now.
Old May 6, 2014 | 03:22 AM
Fede's Avatar
Ticket sent! Waiting for reply.
Thanks!
Old May 7, 2014 | 07:09 AM
evoscan's Avatar
Silver Sponsor
Thanks!
received, and replied. thanks for the extra details to replicate.
Old May 30, 2014 | 07:27 AM
Fede's Avatar
Update:
no answer from 2014-05-12.
2014-05-22 I checked and the status of my ticket was "resolved". I wrote back again, now is still open but nothing happened in the last 18 days.
Old May 30, 2014 | 11:30 AM
ikt's Avatar
ikt
Update:
yup
Old May 31, 2014 | 06:43 AM
evoscan's Avatar
Silver Sponsor
install evoscan to c:\evoscan\
that way Windows File Protection (WFP),part of the System File Checker, can not block your read/write access to the gauges folder.
Old Jun 11, 2014 | 06:27 AM
Fede's Avatar
Thanks a lot.
I'll test this solution.
Is this a common problem?
Old Jun 11, 2014 | 02:39 PM
Fede's Avatar
Tested.
I've lost 40 minute to done all properly and reset all my logging items like before, with right units and so on.
Now it's installed in c:\evoscan and nothing changes, files inside gauges folder are saved with the current date (everytime I save/close them) but when I open my gauge layout I lose all the setting saved: scales, numeric indicators and so on, exactly as before.
Hope to find a solution because I can't use Evoscan if I have to spend 10 minute to set gauges everytime I open my laptop.
Old Jun 16, 2014 | 06:03 AM
evoscan's Avatar
Silver Sponsor
Hi guys,
I'm surprised nobody else has the same issue? or has found a workaround for it yet. I can check it out and fix it.
Old Jul 2, 2014 | 04:29 AM
evoscan's Avatar
Silver Sponsor
ok I found where you were going wrong...
you must change this inside the GaugeMin="0" GaugeMax="1000" in your \Documents\EvoScan v2.9\DataSettings\ xml files.. you can not change it in the GaugeLayout or GaugeTemplate.
I have some code that runs after loading the Templates and Layouts, that resets all the Scale Min and Max to whatever you have specified in the DataSettings xml, the good reason for doing it this way is that you can use different vehicles with the same layout then. i.e. different vehicles may have different Min and Max datasettings files.
