3D SD table - load or VE?
#91
How do you account for the maf being removed once you have tuned a 've table from that maf? If there are truly 've gains then the table would be inaccurate once removed. Could a simple 1d table that accurately represents a factor of restriction be used? Or is that overstating the problem, and could be as simple as adjusting the 've table?
I always enjoy rereading this thread for the knowledge present
#93
Just read the entire thread. Looks quite interesting! I have a car that this can be tested on when ready. I'd agree with keeping it as load based.
I do not disagree at all with charging for this rom. But it does IMO oblige you to a certain level of "support" to the clients.
If closed loop is enabled the trims will give you a good idea of what the difference is. Or you can log the difference in load generated with taking the maf off and adjust the 3D table accordingly.
#94
I know you're probably up to your eyeballs in work mrfred but what's the progress on this? I'm curious cause I got a customer I'm working on with the 3d SD maps and I can only use the 9417 variant due to the stutter with 9653. Yet the 9417 has the warmup enrichment issues so its kinda irritating.
Maybe an ETA on testing?
#95
Been watching this thread for a while now. Is this patched publicly released yet? And will it be around the same cost what Tephra is charging for the Vin locked V2 for the EvoX?
scheides
Oct 22, 2021 08:59 AM
06Black
Jul 6, 2016 12:43 PM
