Evoscan with Surface Pro 2
Old Jun 25, 2014, 06:15 PM
Grimgrak's Avatar
Since evodroid is slower than molasses on a mid winter day... does anyone run surface pro 2 with evoscan? If so are there any problems with it? Any conflicts? Is it JUST as good as a laptop? Thinking about hardmounting a surface pro 3 to the car.
Old Jun 30, 2014, 11:10 AM
xexitenglishx's Avatar
im curious about this too. My gf actually just got one so I may give it a try...
Old Jun 30, 2014, 02:10 PM
andrewzaragoza's Avatar
it should work much like any laptop running windows 8.1 only downside is you only have 1 usb. but shouldn't matter if you log afr and boost using the ecu. plus usb hubs are cheap anyway.
Old Jul 4, 2014, 04:04 AM
Silver Sponsor
evoscan's Avatar
surface pro2 is too expensive.. the latest EvoDroid7 Dual Core are amazingly super fast!!! not like the old Evodroid7. I have both and I find that I struggle to keep my surface pro2 charged via the 300W inverter I have connected to it.
-Hamish.
Old Jul 4, 2014, 04:07 AM
Silver Sponsor
evoscan's Avatar
I have the surface pro2 sits on my lap whilst tuning.. I had to use the keyboard for ecuflash map editing because I have to press the +/- to change the values etc. not too much different to my laptop in the end.
Old Apr 2, 2015, 11:27 AM
benniboi08's Avatar
can anyone let me know what com port is the Surface pro using for USB? I have attempted to log with my Surface Pro 3 with evoscan v2.5 and it allows me to engage "Link engage" but most of the important values are not being recorded.
I'm thinking its one of two things:
-EvoScan v2.5 does not support Windows 8.1
-I am using wrong com port.
Just seeing if anyone else ran into this issue.
Thanks in advance guys!
Old Apr 3, 2015, 05:58 PM
Silver Sponsor
evoscan's Avatar
I am using Evoscan 2.5 with windows 8.1 just fine. also why aren't you using EvoScan v2.9?
also why are you using a com port? everything is usb based these days. None of my stuff uses com ports. all are using USB drivers. and evoscan uses ft2xx.dll which uses direct USB IO tranfsers.
Cheers,
Hamish.
-EvoScan.
Old Apr 13, 2015, 01:24 PM
SmurfZilla's Avatar
I had a Asus T-100 and getting it work consistently with either evoscan or ecuflash was such a headache I gave up. I was in driver hell. Would not recognize the tactrix cable 95% of the time. Just gave the laptop/tablet to my daughter.
Old Apr 17, 2015, 12:44 PM
autocrossn's Avatar
I know this thread is a year old but i have a solution
I build gauge clusters/double dins that are full windows computers
Old Apr 17, 2015, 03:03 PM
miragevo's Avatar
Autocrossn......Why don't you start a tread on building the ultimate windows 8 or 10 double din Evo 8, 9 set-up. I'm very interested in this. I'm ready with the double din faceplate and the climate control relocation faceplate.....Anybody want to but my triple MR gauge pack and factory radio with 15k miles on them?
Old Apr 17, 2015, 03:23 PM
autocrossn's Avatar
I dont have any evo clusters... to test/mess around with
The double dins were originally to expensive for the dsm crowd were i am from $500+
But some new tech has came out to where I can make a double din for around the $300 range.
Old Apr 20, 2015, 09:27 PM
Grimgrak's Avatar
Dont want a cluster just want double din
http://www.ebay.ca/itm/MITSUBISHI-La...3D390851887393
Old Apr 20, 2015, 09:41 PM
autocrossn's Avatar
The double din can run evoscan also.. i just didnt take a picture.
Its a full windows machine same as a laptop
Old Apr 25, 2015, 07:42 AM
edpzwf's Avatar
what is the softwear?
Old Apr 25, 2015, 08:46 AM
Grimgrak's Avatar
Whats stopping you from making one already!
Quick Reply: Evoscan with Surface Pro 2
