Flex Fuel testing in TephraXMOD V3
Old Sep 11, 2015, 07:54 AM
theblackbeast11's Avatar
how is this flex fuel coming my build will hopefully be done by the end of the year think this will be done by then ?
Old Sep 21, 2015, 03:08 AM
tephra's Avatar
aiming for release next week!
Old Sep 21, 2015, 04:33 AM
itzwolf's Avatar
Great news David!
Old Sep 21, 2015, 02:15 PM
richardjh's Avatar
Nice work!
Rich
Old Sep 23, 2015, 05:15 PM
GP148's Avatar
Is v3 going to support SST straight away?
Old Sep 23, 2015, 11:26 PM
tephra's Avatar
In a word: Yes!
Old Sep 24, 2015, 04:25 AM
EvocentriK's Avatar
This is awesome Dave. My evo arrives December. Maybe McCoey and I will have to pay you a visit
This work with the analogue output of the zeitronix Ethanol content analyser?
Old Sep 24, 2015, 04:43 AM
tephra's Avatar
In another word: Oui!
However our Evo friends from Finland are putting together a CANBUS ECA, which means less wiring.
The ECU input being used for the Analog ECA's to use is being borrowed from the Fuel Tank Pressure Sensor, on AUDM there is no such sensor, but there is on USDM.
So while USDM allows for easy connection (being that you just tap a wire and disconnect the real sensor), it has the added hassle of having to override the DTC. Whereas the AUDM car doesn't have a DTC to worry about but there is no wire to tap, so you will either have to find an ECU PIN (I have 50ish laying about if anyone wants one) OR use an alternate method for getting Ethanol Content into the ECU...
Old Sep 24, 2015, 09:19 AM
Registered User
kaganader2's Avatar
Finland... Donner?
Old Sep 25, 2015, 07:44 AM
Gh3ttoRoM3o's Avatar
In a word: Yes!
You prolly get this a lot, but you're my hero. Can't wait for next week.
Old Sep 25, 2015, 04:51 PM
bpk1337's Avatar
Now one of the cool things with V3 (well i think so), is that you can cycle the fuel pump, without starting the car. Just hold down the Cruise-Control Cancel button, and it will spin the pump for as long as you like (and your battery holds up)..
Sorry if this is a bit off topic but does TephraMod V7 have this ability? Would be super helpful for us on the Evo 8 ECU using the FreeFuel patch (linked below).
https://www.evolutionm.net/forums/ec...l#post11512422
Old Sep 25, 2015, 05:28 PM
tephra's Avatar
^ no
but, someone could add it in pretty easy i would think..
Old Sep 25, 2015, 06:35 PM
bpk1337's Avatar
^ no
Boo 8..(.. Would you have time to pick up the baton for the evo 8 guys. Or some how guide me through that? I'm eager to learn. lol
Old Sep 25, 2015, 11:24 PM
Registered User
kaganader2's Avatar
Could write a line to command MUT_D8... I think I remember D8 is the fuel pump prime command
Old Sep 26, 2015, 07:13 AM
So yeah from a noobs standpoint (*cough* mine) what do I need to purchase hardware wise to prepare for this?
Quick Reply: Flex Fuel testing in TephraXMOD V3
