2byte load for 96420011
Old Aug 25, 2016, 10:18 PM
Evo_Goodness's Avatar
Can anyone help me with this i got the MUT table working but there seems to be no definitions for 2 byte load or RPM or airflow for this rom anywhere online its driving me nuts..
So if no one has it can i just use a different 2004 EVO 8 rom and move all my stuff to it such as imob codes and stuff will it even fire up im confused this seems to be the only evo 8 USDM rom with no definitions for this....
PS yes i searched the official 2byte load thread few people asked for it but never got an answer
Old Aug 26, 2016, 04:58 PM
merlin.oz's Avatar
Unless you are willing to pay for a decent definition xml then yes you are best served by moving to a well supported ROM, like 94170715 TephraMadv7.
Old Aug 26, 2016, 05:06 PM
LetsGetThisDone's Avatar
Received 1,543 Likes on 1,322 Posts
Yeah, just move to a 9417 ROM. It'll run fine.
Old Aug 26, 2016, 09:35 PM
Problem is moving to 9417 is the big maps in still learning them and a little afraid I might mess it up I know sounds dumb but not sure if I got it right or not hoping to start learning on just a standard rom and work my way up to big maps and speed density
Old Aug 27, 2016, 09:18 PM
Wait can I move to the standard 94170015 rom and not use tephra just learning my tuning and wanted to start with standard maps
Old Aug 28, 2016, 12:06 AM
Biggiesacks's Avatar
yah that should work no problem, its the universal USDM evo 8 rom, which is why the tephra v7 94170715 is based on it.
Old Aug 28, 2016, 01:51 AM
okay gotcha man thanks before i jump on it and do it do i need to move all 4 under the ECU listing such as. (init code/immobilizer/immobilizer HEX/ECU internal ID)
Or is it just the first 2 ?
Old Aug 28, 2016, 02:17 AM
roni4g63's Avatar
I know you want to stay on the standard size map, but I think the tephra modified roms do need need the imob hex to operate, someone please correct me if i am wrong
Old Aug 28, 2016, 03:32 AM
Yes from what I have read tephra has 2 that you don't touch or the rom changes. I'm wondering about a normal stock rom though though is it all 4 of them I just want to start with a basic stock map that I can get 2 byte load on tune it and move up to tephra big maps
Old Aug 28, 2016, 07:53 AM
its just immobilizer and immobilizer hex. Shops use to change the init code to "Lock" the ecu.
Old Aug 28, 2016, 11:46 AM
Okay sweet man even the ECU internal ID can be left alone then figured it would need all that stuff sweet
Old Aug 28, 2016, 03:29 PM
yah you need the internal id to match the actual rom your using so that your definition file in ecuflash is correct, otherwise it will reference the wrong memory addresses for that rom. So if your using a 94170015 you want to make sure the ID is 94170015 so that ecuflash loads the correct xml definition file.
Old Aug 28, 2016, 03:42 PM
Okay I get it now just don't want to mess anything up thanks for all the help on this man
Old Aug 28, 2016, 03:47 PM
your welcome, asking questions is a good sign.
Old Aug 28, 2016, 06:09 PM
Hmm after flashing it it fires up everything seems good but now my anti lock light flashes with my 1.3u cable plugged in as soon as it's unplugged it goes away is that something Mitsubishi added on later roms.? Doesn't seem to affect anything
Quick Reply: 2byte load for 96420011
