need help setting SD, car lean and stall
Old Nov 4, 2016, 01:51 PM
PL_MR's Avatar
Hi,
I was using V7 with direct boost control option and I'm trying to go SD.
I start by tune de VE RPM table like said just at idle. that's good.
Next step, go light throttle and tune de VE load map. Can't. As soon as I lauch in first, the fuel lean out and car stall???
It's like if I have to higher the value in the load map instead of lower them?
When I log the manifold air temp, it's 200deg and AIT is 66.
Would I have a problem with the scaling of the MAT and it's causing me all those problems?
Thanks
Old Nov 4, 2016, 02:31 PM
PL_MR's Avatar
I forget to say, I do it using the the fuel temp sensor and my option of MAT is set to 0E
Old Nov 6, 2016, 08:06 AM
PL_MR's Avatar
Found the problem for the MAT reading 200deg, found reading too many post a guy that have same issue. When I copy the code in evoscan, the request ID is set to 09. but it need to be to 11. So fuel sensor is working good, this is not the problem. I double check the setting for fuel cuet, it can be interpret like that, it's lean so quickly but they are fine.
Is there other function that can do a fuel cut for protection other than the fuel cut load ?
jtbell86
11
Aug 1, 2020 09:23 PM
maxspeed96ct
Sep 4, 2016 05:50 AM
richardjh
42
Apr 20, 2011 05:21 PM
SteveThePirate
12
Apr 15, 2010 11:49 AM
bbyevo8u
Feb 11, 2009 09:17 AM
Quick Reply: need help setting SD, car lean and stall
