8 RS 2.0 3586 E85 400whp-700whp
AEM Infinity
12 position trim switch
4port boost controller
FIC 1650cc - 83%dc - BFP 53psi
ETS Ti UICP
Stock Rebuilt Throttle Body
CB Ported IM
Light port to head
Supertech Dual Springs + Retainers
SS Valves
GSC S2 Cams
ARP 625+ studs
CP Pistons 10.5:1
Carrillio Rods
Stock Crank
JMF Vband Exhaust Manifold
FP 3586 .63 Tial housing
Pump E85
ETS Ti UICP
CB Ported IM
Light port to head
SS Valves
GSC S2 Cams
ARP 625+ studs
CP Pistons 10.5:1
Carrillio Rods
Stock Crank
Pump E85
Nope, I wanted the faster spool on the .63 hotside. The car is to fast as it is. I am going to switch to a much smaller turbo next year, thinking bout the FP 3076. I drive the car in Mode0 == 420whp. I think I am getting old .
I stopped turning the boost up at 32psi, just because it was already way to much power for me. I like to road race the car, so much less will be better.
ALso this was a dyno rental. So I was tuning the car. They were just running it on the dyno. Getting to old to be street tuning also , a sad day.
12 position switch setting
0 = 200kpa(400whp)
1 = 220kpa
2 = 240kpa
3 = 260kpa
4 = 280kpa
5 = 300kpa
6 = 320kpa(700whp)
This is the AEM Infinity, the car had a series 1 on it before. With the AEM's you just need to spend a little time tuning cold/warm/hot starts and you will have it running like a champ.
I am in Southern Cali so it does not get cold here, our cold is like 45* .
Here is a quick start up video.
Thanks.
In a few months I am going to go back to the dyno and crank it up to 40-42psi and see what it will do. Then the smaller turbo will be in order . I wanted to get some road racing in before I really beat on the car. As it sits I drive the car at the 400hp level.
I also want to pull the trans and tcase for a rebuild, they need it bad. The evo has 130k on it now.
They will have a PNP kit soon for the Evo, but I had to build my own harness. The infinity super nice. Way better than the Series 1/2. It is also VE so once you set up your VE map, everything else is just trims and feedback settings. The PID controllers are very fast.
Did some road racing this weekend. The 400hp tune was awesome for the track.
Evo 8 RS AEM Infinity Robi Spec KW Race - YouTube
That is one awesome track
