BBK Full, SD, Stock Mani, Cosworth Cams, Stock Bottom End, etc on 93
Yeah you should have alot left on the table, I made very good numbers with a little boost and few degrees to play with. I only changed manifolds to really push the bbk full and see what I could get out of it. Stock manifolds aren't hurting anything. I love the turbo, it spools damn close to stock and will make more than enough power for the street! Everyone that rides in my car are most surprised by how responsive the turbo is compared to how hard it pulls lol.
Check for the exhaust rubbing on the oil pan or cross member, any of the intercooler pipes rubbing something metal, etc..
False knock can also just be "noise" from inside the engine that your tuner doesn't know enough to know what's normal, and what isn't.
Judging by the fact you went with him due to "pricing" tuning isn't something you want to cheap out on. If you take the car to CBRD, they can do thorough and good job of looking the car over, and tune it correctly for you.
IzzyRS (Feb 3, 2017)
Thanks everyone for the speedy responses to my questions!
Someone else should chime in, any second now, that can explain it mo' betta'.
I believe it's because the exhaust gas velocity is faster with the smaller tubing.. but it's been years since I looked it up. Been with cast manis for about 10yrs now LOL
P.S. I'm assuming you mean an equal-length tubular mani. If you mean a tubular "stock replacement", then those work pretty well. Though mine still cracked. LOL
If you are close to CBRD, give them a call. I'm sure they can extract some more power safely. No need for a tubular manifold, just port your stock one if you want to. A tuner with plenty of Evo/4g63 experiencee can really make the car a different animal (while keeping the block together).
The only thing is that I dont know if i want to drive that far semi-regularly to pay for a re-tune after I install new parts. but theyre still my top go-to unless I can find something reasonably closer
Theyre about an hour and a half from me, but ill drive much longer for quality. Thanks for the help
(see my Sig)
This question isnt particularly aimed at anybody. But is CBRD the go to shop for PA? Im just curious if there are any others just for comparison. I know this is slightly off topic but more recommendations are also welcome.
If you are needing to visit a shop in person, that is a good place to go. You won't be disappointed. If there are others in your area, then that is even better and quite fortunate for you! Some people drive really, really far just to find one, single shop LOL
