DIY: Viper 5701 Install on CT9A
Old Feb 24, 2009, 12:33 PM
  #31
biggie5252's Avatar
Yes cut it. Car side to the violet wire, key side to the green wire.
Old Feb 24, 2009, 01:47 PM
  #32
sadc's Avatar
ok last question. How do I setup to lock it while my aftermarket turbo timer is running? And for the hood pin. Do I have to use it for the remote start or can I just ground it?
Old Feb 24, 2009, 03:08 PM
  #33
johnjonfenomeno's Avatar
you don't want to ground the hood pin.. It's a negative trigger meaning leave it open. As far as your aftermarket timer.. I would just use the one provided by the alarm.
Old Feb 24, 2009, 04:01 PM
  #34
sadc's Avatar
So I can just close it off then huh? and my remote start should work. Pending if I did the Tach learn already?
Old Feb 24, 2009, 11:45 PM
  #35
sadc's Avatar
what is this for?
"Accessory Output----------------------------------orange--------------------------blu/wht"
Do I need to hook this up?
Old Feb 25, 2009, 12:11 AM
  #36
biggie5252's Avatar
Yes, just tape up the hood pin wire. As long as there's nothing else preventing the car from starting it should work.
The accessory output is what will power your heater/fan and whatever else happens to be powered from that wire. It's not required to be hooked up for the RS to work, but it kinda defeats the purpose if you don't.
Old Feb 25, 2009, 01:47 AM
  #37
EVOIXMR8916's Avatar
pm me if you need a viper remote start or security system very competitive price on a few i have laying around....
Thanks,
-Dan
Old Feb 25, 2009, 02:13 AM
  #38
sadc's Avatar
Oh sweet! ill try this out when theres light out. My car was apart for 2 days now and I want to drive it ....but riding my gsxr 750 lately and man has it been cold. Anyways Thanks man. Oh yea im still wanting to know how to setup the alarm to arm when my aftermarket turbo timer is still running. Someone said they know how to do it
Old Feb 25, 2009, 02:15 AM
  #39
sadc's Avatar
Thanks,
-Dan
can beat the 155$ brand new viper 5701 that I got at least i hope not
Old Feb 25, 2009, 02:35 AM
  #40
sadc's Avatar
oh yea totaly forgot. I cant seem to get my parking lights flash to work. On my car its "Parking Lamp Green/White (+) at relay or fuse block (#5)"
So I taped into the green/white wire under my driver side kick panel and I get 11 volts when I turn on my parking lights. I tried to do that fuse things on the RA unit(theres only two ways I can do I can change the polarity if im not mistaken) And I still get nothing?!?!
Old Feb 25, 2009, 08:03 AM
  #41
can't believe this aint a sticky yet? .. I write this kick *** how to .. i think I deserve a sticky
Old Feb 25, 2009, 08:04 AM
  #42
I will soon edit the original post with pics on accesory installation such as garage door opener using the 5701 , trunk release kit installation and other cool stuff you can do with this alarm.
Old Feb 25, 2009, 08:31 AM
  #43
what is this for?
I used it to power my rear defroster.. but being your in 5-0 i dont think it would be of use.
Old Feb 25, 2009, 09:21 AM
  #44
sadc's Avatar
John....do you know how to fix the parking lights to come on when armed and disarmed? oh yea...im using the (+) on the parking lights. dont know if that helps
Old Feb 25, 2009, 10:35 AM
  #45
- If you open the compartment inside the brain unit you see that there is a spot for a 10amp mini bus fuse. This has to be hooked up for a positive polarity pg.55 of install manual
I believe you have to set the polarity in the brain. I had a similar problem and that seemed to solve it.
Make sure the bus fuse is inserted all the way in
Quick Reply: DIY: Viper 5701 Install on CT9A
