Unknown wire hanging?
Old Aug 22, 2016, 11:14 PM
fugiwara's Avatar
What is this black wire? found it hanging, where does it connect to? Please help, thanks.
Old Aug 23, 2016, 07:34 AM
Received 1,384 Likes on 1,317 Posts
Its got a body clip attached to it. If you dont get an answer today, Ill pop the hood after work & see if I can find it on mine
Will let you know
Old Aug 23, 2016, 05:14 PM
Sorry, I checked but dont see any similar connector. I have an RS so they could be the reason
Can you trace that harness or does it go into a bundle?
Old Aug 23, 2016, 07:49 PM
evo_nation's Avatar
Looks like it's right on the back of the power steering pump. Mine has two body clips on it.
fugiwara (Aug 23, 2016)
Old Aug 23, 2016, 11:27 PM
fugiwara's Avatar
it's a bundle
Old Aug 23, 2016, 11:51 PM
fugiwara's Avatar
Looks like this is it, but now I found a blue wire hanging
Old Aug 24, 2016, 07:12 AM
evo_nation's Avatar
The black connector should hook up to the blue wire connector and the blue wire goes to the back of the pump on mine.
fugiwara (Aug 24, 2016)
Old Aug 24, 2016, 09:38 AM
fugiwara's Avatar
Bingo! looks like I am missing a plate too, thanks so much for your help evonation.
Old Aug 24, 2016, 09:40 AM
fugiwara's Avatar
Can you check one thing for me? does the blocking plate attached to power steering pump or sits on AC compressor? thanks in advance
Old Aug 24, 2016, 11:41 AM
evo_nation's Avatar
1 bolt and it goes throu the power steering bracket.
Old Aug 30, 2016, 05:25 PM
fugiwara's Avatar
thank you very much, I talked to a tuner and mechanic they said that wire isn't important, I might just leave it alone for now.
Old Aug 30, 2016, 09:39 PM
evo_nation's Avatar
Did they tell you what it was for?
Old Aug 30, 2016, 09:54 PM
Pal215's Avatar
Not 100% on this, but it could be the wire responsible for sending the signal to the ecu that ramps up idle when using the steering wheel.
-pal215
Old Aug 30, 2016, 10:34 PM
fugiwara's Avatar
-pal215
Yes, you're right
9!'clipseDOHC
Aug 11, 2012 03:39 AM
haloevolution45
Oct 5, 2007 01:00 AM
XK120
Feb 2, 2007 09:47 PM
TheSeige
Aug 1, 2006 04:36 PM
Quick Reply: Unknown wire hanging?
