Oil blowing from oil cap/dipstick
Hey guys any of you having problems with getting oil blowing out of your dipstick and/or oil cap. Im getting alot of blowby, rings are seated good, good compression. IM running an aftermarket T3/4 turbo on 18psi. Anyone else have this problem??? If so what did you do to fix it? I know I can disconnect the vent from the valve cover to the intake manifold and put it into a catch can, but will that solve my problems?
for a while my dipstick used to pop out part way so it isn't sealed and i used to get oil all over my engine. i bought a spring and put it around my dipstick and the bracket that mounts it to the block, to keep it down where it is supposed to be. i also had a catch can, so having one won't solve the problem, although you should get one for other reasons. maybe i just have a bad gasket though on the dipstick.
oil was leaking around my cap just a little bit... i figure its because i got one of those $5 ralliart knockoff oil caps from ebay... tossed it now im fine lol!
Alot of the dsm's did the same thing. But to get the dipstick to come out u really gotta beat on it. Maybe since u have a larger turbo thats the reason 4 it. Or maybe mitsu still hasen't fixed this problem from the 1st gens. Try to zip tie it 2 something. Thats what we use2do.
you may need to drill n tap out your rocker cover breathers for larger fittings and tubes leading to a catch bottle with equally large fittings then remove spring from dipstick just an idea, its been done to mine. ( evo 5 engine 2100cc HKS crank rods pistons cams pullys injecs. etc. etc. )
I think thats ultimately what it is, I got a cheap *** ebay oil cap and I know for a fact the O rings on the dipstick are OK. Im gonna do another compression test later, I did one of the other day and came up a little low but thats also because the engine wasnt warmed up and it was 14 degrees outside. This is a new engine with just under 1,000 miles on it so the rings may not have fully seated yet, also you can tell if you got bad compression by driving the car, you'd get some blue smoke and especially when really laying into the throttle it would feel weird, the car feels incredibly strong. Im gonna do another test tonight then post up my results.
it doesn't matter if your compression is low, as long as all numbers are around the same compression, then you're ok. if replacing the oil cap does not solve your problems, what oj said will.
basically,there's a restriction in your crank case airflow, securing the dipstick by various means, will only force the pressure to go somewhere else, only creating future problems. There's a reason serious guys run -10 an lines from the valve cover to the catch can, and it's not for bling.
o3evo8
Apr 26, 2017 03:59 PM
Slo_crx1
Jul 6, 2011 02:38 AM
flyguycfi
Jul 21, 2009 03:27 AM
