Mitsubishi OEM turbo specifications (including flow rates)
Old Jan 2, 2008, 05:41 PM
  #31
dannys EVO IX's Avatar
i have a IX se
but i still would like to know , how it would compare my turbo specs and max HP to the FP Green
Old Jan 21, 2008, 11:08 AM
  #32
humanizer's Avatar
Yeah! Im running a Evo IX GSR turbo in my Evo IV. What is the Max power output/ boost with that turbo?
Old Mar 5, 2008, 04:12 AM
  #33
C6C6CH3vo's Avatar
The largest turbine housing available for the TD05-16G (bolt-on for VIII turbo) is the 10.5 cm˛?
Old Dec 2, 2008, 06:01 AM
  #34
Robevo RS's Avatar
why is not here the X turbo yet?
would somebody post it?
/i'm not a right person for that/
Old Dec 2, 2008, 10:06 AM
  #35
wesside's Avatar
no **** Where is the X turbo at?
Old Dec 3, 2008, 05:57 PM
  #36
TwistedEvo8's Avatar
Yes im interested to see the X turbo my self.
Old Dec 3, 2008, 06:05 PM
  #37
Evolution IVGSR's Avatar
Sick and thanks for the info {thumbup**
Old Dec 3, 2008, 06:53 PM
  #38
wesside's Avatar
Get another Evo Dallin haha
Old Jan 4, 2009, 12:36 AM
  #39
runovr 33's Avatar
will post some tomorrow broke a rear wheel off at the track today evo x rs jdm spec ecu tec tuned 3" dump and straight throu. from down under
Old Mar 24, 2009, 08:27 PM
  #40
Registered User
rolly1818's Avatar
bump, anyone with a compressor map for the Evo IX GSR?
Old Mar 28, 2009, 02:12 PM
  #41
Evogargoyle's Avatar
The only thing that I'm missing from all the wicked specs are the flange dimensions, For the manifold to the turbo. Especially for the Evo 1 W/ stock turbo? PLEASE HELP!!
Old Apr 25, 2009, 03:01 PM
  #42
Ponce51's Avatar
i dunno if this is off topic, but i was wondering if anyone knew the inlet diameter for the 9 stock turbo, but very good thread, theres alot of helpful info on here thanks guys
Old Apr 26, 2009, 03:44 AM
  #43
Danieln's Avatar
1.6 boost level was the turbo’s limit with the temperatures it generates at 6000 RPM which was the designs limitations.
Attached Thumbnails Mitsubishi OEM turbo specifications (including flow rates)-stock-turbo.jpg
Old May 8, 2009, 03:12 PM
  #44
05onblocks's Avatar
what about the 05 i heard that they have the best turbo out of the evo 8 lineup. i know mines the 10.5..
Old May 8, 2009, 03:37 PM
  #45
wesside's Avatar
for a evo 8 yes port that lil sucker and it will treat ya right
I've had a stock 8 turbo 10.5hs, fully ported 8 turbo 10.5hs, ix turbo (come 10.5hs) and now a green on my car. I'd say for the cheapest upgrade go directly to a ix turbo or just port the 8 turbo if you can do it or have someone do it and the one I had on my car was ported on the turbo outlet part as well as the intake side and ported 10.5hs on it but if you've got a chance to grab a ix turbo for cheap then snag it
Quick Reply: Mitsubishi OEM turbo specifications (including flow rates)
