Smell of coolant inside the car? Also cooling issues?
So I recently replaced the coolant and I replaced it with Redline's Water Wetter, Prestone coolant (~35%), and distilled water mixture. After driving for a few days, I noticed a smell of coolant when I turn the A/C on (no smell when compressor is off). When I parked, I notice a puddle of water coming out....although didn't smell like coolant. This liquid drained from a 90 degree pipe out of the cockpit firewall. So I'm guessing it's A/C.
I checked all my hoses for any leaks or crack, I didn't see any. Last night, the car overheated. So this morning, I follow the Service Manual's procedure (exception of drain the coolant from the engine block). I filled the reservoir and the radiator again. I ran the car and seemed fine. After the car cool, I discovered that the reservoir is empty and the radiator took WAY more additional coolant that it should!!! After I ran the car, I did not see any obvious leakage while the engine was running/still hot.
Any idea??? Can the coolant somehow leak into A/C system through the A/C heating system? I know that A/C and engine cooling system are separate, but how can I smell coolant in the A/C???
Sme happedned to me, it was a faulty heater core. BEWARE it may cause expensive damages to the engine. I replaxce it with a Lancer Ralliart core. All lancer's heater core are identical.
As for the puddle, it's a little concerning. I'm aware that A/C will generate water through the evaporator, but this one is dripping more than a few drop a second (it's just a little too much). I purged the system after the fact and my reservoir was drained! Something wasn't right. Thank you for the suggestion though.
Evoryder
Apr 29, 2019 10:09 AM
