Low Compression on all 4 cylinders
Are you holding the pedal down while cranking? All other plugs out and a charger on the battery? I saw a difference in my psi numbers without a charger but I do have a mini battery.
I got my motor apart n foumd ALL 4 top piston rings came out in pieces and I had 160psi in all cylinders with S2's
Yep I followed the manual to a T when doing the compression test. I also did a cylinder leak down on all of the cylinders and they were all within 10% or so. I have read. With larger cams the over lap will cause this. It's just me being paranoid
2009, compresion, compression, compression test, cylinder, engine, evo, evolution, evom, gauge, lancer, leakdowntest, low, motor, stock
