Battery Relocation OEM EvoX (Part Numbers)
Old Jul 8, 2013, 01:01 PM
XSilverJ's Avatar
Post Battery Relocation OEM EvoX (Part Numbers)
So my car originally came with a very bad hack job of a battery relocation to the trunk, of course there are many kits out there and some very good DIY guys, I like things to look OEM and keep it simple really, and also I'm not an electrical guy by any means.
I originally found this in another battery relocation thread that I'll try to dig up later to credit the guy who posted the picture of it done, but that was the problem it was just a picture with no info lol
After multiple PM's and lots of thread reading I could only find two part numbers I needed and wasn't sure of all the parts needed or if they were correct. Called up my friend with a X and had him come over so I could get pictures of all the parts and look them up myself, here you go for the multiple other people with me that were asking about it
3 things:
Part Number: 8571A017 (Joint Wiring) This is the plastic part that everything bolts to and for you make a bracket for to mount in the bay)
Part Number: 8571A018 (Fusible Link Cover) The red cover over the fusible link to hide everything and make it clean looking)
Part Number: 8571A019 (Fusible Link) The fusible link that you will connect all your wires to
Ordered from JNZ Tuning
The black plastic mounting piece with the fusible link held together
Whole setup together
a little bracket made and voila this is where mine will be sitting got some engine bay cleanup to do but it's getting there
7318b4e5-b1e9-4cb5-97d6-105b32db9ab5.jpg?t=1373313496
Old Jul 8, 2013, 06:24 PM
211Ratsbud's Avatar
very good idea, what did you use to hold the battery in the trunk?
Old Jul 8, 2013, 07:21 PM
XSilverJ's Avatar
It was there when I bought it, but it's in a battery box
Old Sep 28, 2013, 01:09 AM
car_nut15's Avatar
As far as wiring did you simply transfer all the wires running to the original terminal to this? Are the fuses the correct ones or did you have to change any of them out?
Old Sep 28, 2013, 02:35 AM
XSilverJ's Avatar
just transferred everything over, no issues so far
Old Sep 28, 2013, 09:21 AM
Frew's Avatar
did this a while back, here is mine.
Old Sep 28, 2013, 09:47 AM
Boosted Tuning's Avatar
Awesome. I saw this about a year ago in some thread here (prob same on you saw it in, just a pic, no info). A bunch of cars that come into my shop have the battery relocated, but a mess in the front (usually an all tapped up connection). I tell people to do this, but never had the part # for it. Thanks
Old Sep 28, 2013, 04:33 PM
16vEVOIX's Avatar
Thanks for sharing the part numbers. Did you run the battery cable from the front of the car to the trunk through the interior of the car? Or did you run it underneath the car?
Old Sep 28, 2013, 08:50 PM
XSilverJ's Avatar
No problem guys, you're welcome. I hate looking for information and nobody giving it up or helping
Cable is ran through the interior
Old Sep 28, 2013, 08:54 PM
sktng22's Avatar
nice. good info gonna do this soon looks clean
Old Sep 28, 2013, 10:26 PM
egis's Avatar
megan tubular EM?
Old Sep 29, 2013, 07:48 AM
Frew's Avatar
MAP short runner
Old Sep 29, 2013, 07:54 AM
car_nut15's Avatar
Just out of curiosity did you use an in line fuse or breaker of some sort with this? What size power cable and ground did you use? Did you run the power cable through the firewall or fender? Thanks for sharing!
Old Sep 29, 2013, 09:37 AM
EvoM Community Team
golgo13's Avatar
I'm curious as to how the additional cable length alters the electrical system. It should change draw, resistance, etc.
Need an electrical engineer to chime in here.
Old Oct 1, 2013, 02:47 AM
AnabolicEVO's Avatar
Awesome thread. What was the prices for these parts?
Quick Reply: Battery Relocation OEM EvoX (Part Numbers)
