Just got my rebuilt motor had some questions.
I don't think the machined shop actually test the compression. they would have needed an engine stand with a war to mount the starter and spin the motor over. It would also be poor practice to do it without an intake manifold on the head with some kind of air filter. 185psi would be a fresh 9.5 or 10:1 motor.
Yea the machine shop might have just jotted those numbers down off the dome.
Because 180 psi is usually found in a lot of engines so he probably just wanted to sound perfect.
It needs to be ran...
I think every machine shop has at least a few $80k machines...lol
Yup.
If you did not change any components other than just rebuilding the motor, you should be ready to rage and just control the break in with your right foot.
I have seen forced induction miata guys just start it, change the oil, then go run 10 naturually aspirated WOTs followed by full boost wots to seat the rings, change the oil and then rip it.
It is also good to note that Chrome (or any super hard metal) rings will need to be run more like this method to ensure good seating. Steel rings are a little bit easier to seat with just running mildly.
Remember, whatever you do, you want to make sure those bastards are seated before putting synthetic in the motor. If you put it in too soon, you will stop the seating process and be stuck with a motor that burns oil.
Hope this helps.
If nothing else has changed just the rebuild you don't need a retune. Just focus on putting everything back together correctly. Start it up, make sure there are no leaks and you have oil pressure and no CEL's. Then get it all the way up to operating temperature, the oil too not just the coolant, then go rip on it like you just robbed a bank.
Thanks for the help. I'm gonna change the oil at 500 miles and use conventional for another 3,000 probably before I even switch to synthetic I think. I wanna make sure everything is seated good before I use any other oil
HawkeyeGeoff (Oct 28, 2016)
i say, get it running. make sure you have no misfire or leaks. record fuel trim. if fuel trim looks ok, do the break in. then find a good tuner. a good tuner would know the potential of the built engine with the given specs.
