Weird scraping noise from Engine or under the car(?) HELP~
Old Mar 20, 2006, 03:37 PM
Rod Munch's Avatar
Originally Posted by djscoto
Very good suggestion
Thanks!
(Too bad it sounds like I was off-base. But it's worked for me with other cars.)
Old Mar 20, 2006, 04:15 PM
mybada's Avatar
Originally Posted by hondafan
is it when you barely have your foot on the gas?
Yes, it happens only when I barely have my foot on the gas pedal
Got any idea what that is?
I took off my High-flow cat which was NOT the problem.
I'm gonna try stock BOV tonight. I will post result later.
Old Mar 20, 2006, 04:17 PM
gsrboi80's Avatar
Originally Posted by ashton13
dude... its an evo... unless my car breaks down im not worried about noises...
+1
Old Mar 20, 2006, 04:28 PM
App420's Avatar
i have the same problem, its the t-case... it wont affect drivability other then noise... only way to change it is to replace tcase... to expensive to fix and iv gotten this looked into by multiple reputable perf shops...
Old Mar 20, 2006, 05:08 PM
mybada's Avatar
Yeah, looks like it won't affect drivability since my car still runs pretty strong.
but man... this was the news I was hopping not to hear... :*(
Old Mar 20, 2006, 05:43 PM
App420's Avatar
Changing tcase fluid on monday... will find out if it gets quieter but I was told that it wouldnt solve the problem...
Old Mar 20, 2006, 05:57 PM
Registered User
cdavy's Avatar
I had this and thought it was a wheel bearing. Seemed to get worse with brakes the clutch make no differences... I was going to take it into Mitsu and it disapeared...
Old Mar 20, 2006, 07:36 PM
nnorris7413's Avatar
I have the same problem and i changed the t-case fluid and it really didnt do anything.
Old Mar 20, 2006, 08:08 PM
hondafan's Avatar
^same here. sucks cause i've only launched my car one time(honestly)and don't even beat it much. i've got 26,000 on my stock clutch. of course, you go to mitsu and it's normal! BS, grinding in a TC at any time is not normal!
Old Mar 21, 2006, 06:09 AM
Silver05Bullet's Avatar
dude it seems like many evos have it including mine its not really that loud on mine but it can be heard as well, ive had people look at it as well and tell me its all good, and no need to worry the evo makes way too many noises, just drive your car if something goes wrong then worry about it.
Old Mar 21, 2006, 11:04 AM
mybada's Avatar
yeah, I think you are right.
I replaced my high-flow cat with stock cat and
I replaced my MR BOV to stock one last night, didn't do anything.
Well, I know they're not related to this issue but for some reason I just wanted to try.
So it seems like the noise is from T-case and there's no solution other than replacing T-case?
We are driving $30K+ car and have to live with noise...sad
Old Mar 21, 2006, 11:31 AM
nukblazi's Avatar
I have the same noise, from what I can tell. Not worried about it, if you can adjust backlash I think you could dial it out.
Old Mar 21, 2006, 11:41 AM
su37su's Avatar
so how much is it to replace the T-Case?
Old Mar 21, 2006, 11:54 AM
brooks1005's Avatar
I have the same noise but I believe its my helix dp rubbing on the oil pan.I was under the car and noticed there is only an eight of an inch or less between the two.The dealership said the same thing after they looked at it.Any movement by the engine will cause the tbe to hit the pan.
Old Mar 21, 2006, 12:04 PM
hondafan's Avatar
i wouldn't replace the TC with another mitsu one. you can send the one you have to sheppard racing and have it freshened to his specs much cheaper. TRE performs this service as well, but i prefer shep since all the big dogs run his trans and TC's. al, AMS, and buschur to name a few.
Quick Reply: Weird scraping noise from Engine or under the car(?) HELP~
