I need help with with evo 8 ecu
I need help with EVO 8 NO START!!!
I was wondering if anyone can help me with this .. 2005 evo 8 mr
crank but no start.. fuel pump cutting on, and injectors are firing
everything occurs with key on engine off..
I am not getting a ground to my crank sensor, cam sensor, nor maf sensor. Instead its getting 8 volts. All other terminals of the above sensors (crank,cam, and maf) plug have the right voltage as far as 12v, 5v.
Another issue is with the ignition coil. I haven't been able to get my hands on a schematic for the ignition circuit but i am getting 6v coming from the signal line with it unplugged from the coil. i know it should be a ground.
Im pretty sure is the ecu but i just need some opinions on the issue.
ran separate ground and crank, cam, and maf are reading now. ( ecu is not holding the ground.. going to see if there is another ground wire for the ecu and check if its open.)
Now as far as the ignition coil... i used my test light to check if the coil was getting the signal to fire cylinder 1 and 4 constant power( not cycling power to ground) cylinder 2 and 3 firing ( cycling power to ground). i would think there's something else in between the the coil pack and the ecu on that circuit that could cause this but i dont have a schematic to see.
UPDATE:
replaced ecu and that solved ground and ignition coil constant power issue.
Now its not starting
Fuel- good
spark-check
timing -dead on point
when in evoscan with key on my timing reads 61 degrees but when i crank, it goes to 5. i going crazy right now as there aren't any codes coming up and the car will start for 1 second then stall. when it stalls if gives off a backfire pop as if the timing was off but it isn't. and i can smell unburnt fuel coming from the exhaust. i also have brand new plugs in there gapped at .025. Is it possible for the ignition coil to cause this or a crank angle sensor.
any feedback from the log ?
UPDATE:
Fuel- good
spark-check
Its a no start.. im getting fuel, im getting spark and timing is dead on. maybe the crank angle sensor but if it were that it wouldnt fire the spark plugs correct ?
i dont know wtf is going on and its driving me crazy. i have spark, im getting fuel, and i checked the timing (cam sprocket lines lining up with valve cover lines and crank marking lining up with tdc mark for 0 degrees on the lower cover)... i even disconnected the injectors and sprayed starter fluid. the only thing i got was backfire out the intake which suggests that the timing is off. this is base rom from an evo 8 with the immobilizer disabled...... Can someone send me a base evo 8 rom with the immobilizer disabled. maybe im not disabling it correctly.. im starting to run out of ideas
Raceghost
Jun 17, 2016 04:05 PM
Mitsubishi ^_^
Lancer Troubleshooting
10
Jun 14, 2016 01:54 PM
tboboy
Aug 7, 2010 03:39 PM
