My Evolution Wont Start...
Old Jan 31, 2015, 07:00 PM
flippymcbean's Avatar
Just recently finished up my clutch install....just buttoned everything up and was going to start the car and nothing.
All the dash lights come on radio and accessories..., when I turn the the radio goes off and the clock does the same thing. also when I turn the key to start the car I can hear the fuel pump. Sometimes I hear a clicking noises as well. The car will not turn over what so ever.
I've read a few threads stating that it could be the starter. And I'm leaning towards that, but does anyone have any advice what else to check?
Old Jan 31, 2015, 07:08 PM
robbyredneck's Avatar
did you put the main ground back on the "bellhousing" bolt?
Old Jan 31, 2015, 08:57 PM
Yeah. I forgot which one it was. But I did put it back on. It's bolt/ground/bell housing right?
If your looking at the flywheel I put it on the left one. Should that matter?
Thanks.
Old Jan 31, 2015, 09:37 PM
heel2toe's Avatar
How long was the car down for? Any chance the battery is just weak?
Old Feb 1, 2015, 02:15 AM
MR. EVO MR's Avatar
^ ^ good point
Are the plugs connected?
Old Feb 1, 2015, 04:15 AM
Yes the car was down for 4 months. All of the plugs are plugged in as well.
I wish I. Ls read the computer, but my cable is in my friends car and NCIS now has his car.
Old Feb 1, 2015, 04:17 AM
I'm assuming the batter is just horribly weak. I bought a used PC680, tried to jump it and nothing. Even tried using my old battery still got nothing.
Old Feb 1, 2015, 09:56 AM
AJCaron12's Avatar
Are the battery cables completely tight on the battery posts? You should not be able to move them at all.
Old Feb 1, 2015, 05:02 PM
As snug as can be. Is there a way to self test the starter?
Old Feb 1, 2015, 05:51 PM
mrowka's Avatar
Location: Driving ten under in the passing lane, right turn signal on at all times.
Neutral safety switch thingee?
Old Feb 1, 2015, 06:24 PM
9mr3vo's Avatar
What about the starter remote wire that connects to the starter? should be a black female spade connector.
Old Feb 1, 2015, 07:17 PM
Neutral safety switch? Is the the clutch pedal switch as well? That is also disabled/unplugged for my remote start. I did however plug it back in to try it...and still got nothing.
Old Feb 1, 2015, 07:20 PM
Are you talking about the small black plug above the power wire? Yes that has been plugged in and out numerous times.
Thanks for the suggestions guys!! Keep them coming.
Old Feb 1, 2015, 08:55 PM
4RETECH's Avatar
Yes. That to power you should activate the starter
Old Feb 2, 2015, 07:19 AM
So I took ouy my starter again. The top bolt to my starter is stripped and I cant get a torque on it. It was snug, but not as snug as I wanted. Could this be the culprit?
Quick Reply: My Evolution Wont Start...
