CA smog😡
Old Apr 24, 2016, 10:14 PM
benIX's Avatar
CA smog😡
Hello Evo M,
My car is due for the great California smog ����. Problem I'm having is with the new smog law you can only have evap system not ready. Now being tuned my rear o2 sensor has been cancelled. Is there anyway to get it to show ready without having to go to a Tunner? I just want to smog my car and start modding it ��
Thanks in advance,
Ben
Old Apr 24, 2016, 10:43 PM
Biggiesacks's Avatar
sure, you just need to purchase a logging/tuning cable from either tactrix or evoscan and then do some reading in the ecuflash subforum. You should take a look at the sticky thread that lists all the important tuning threads, paying particular attention to the one about emissions testing.
Old Apr 24, 2016, 10:50 PM
benIX's Avatar
I do have a tacteix cable ��
Old Apr 25, 2016, 11:44 AM
then all you have to do is read and download some free stuff.
Old Apr 25, 2016, 12:49 PM
thatguy5's Avatar
Yep, its really just a matter of flipping a couple bits to get your car to force pass smog
Old Apr 25, 2016, 04:05 PM
Klaiceps's Avatar
https://www.evolutionm.net/forums/ec...us-mrfred.html
Old Apr 25, 2016, 07:47 PM
benIX's Avatar
is there a video on this guys the video posted is not working. thanks guys
Old Apr 25, 2016, 07:56 PM
kaj
kaj's Avatar
From what most of us can tell, you have to keep trying different settings until you find the ones that work. There's no one universal six for all cars.
Old Apr 25, 2016, 08:00 PM
there is some smog equipment that the evo did not come with, so setting that stuff to ready/pass will trigger a fail.
Old Apr 25, 2016, 09:34 PM
benIX's Avatar
ok so i am really frustrated. i got ecuflash installed on my computer and this it what it looks like.
[21:29:54.177] EcuFlash Version 1.44.4671
[21:29:54.177] OS Version Windows 7
[21:29:54.177] Kernel Type winnt
[21:29:54.177] Kernel Version 6.1.7601
[21:29:54.178] CPU x86_64
[21:29:54.178] Product Name Windows 7
[21:29:54.178] Product Type windows
[21:29:54.178] Product Version 7
[21:29:54.178] Qt Version 5.5.1
[21:29:54.178] Qwt Version 6.1.2
[21:29:54.178] QwtPlot3D Version 0.2.6
[21:29:54.178] Boost Version 1.60
[21:29:54.178] FTDI Library Version 3.02.11
[21:29:54.178] Openport J2534 Library Version 1.01.4671
[21:29:54.214] 67 memory models read.
[21:29:54.215] scanning for metadata models in C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata
[21:29:55.196] 748 ROM metadata models scanned.
[21:29:55.196] checksum module "subarudbw" loaded.
[21:29:55.196] checksum module "subarudiesel" loaded.
[21:29:55.196] checksum module "mitsucan" loaded.
[21:29:55.196] checksum module "mitsuh8" loaded.
[21:29:55.196] patch module "Subaru CAN Enhanced RAM Parameter Logging" loaded.
[21:29:55.196] patch module "Mitsu CAN RAM Parameter Logging" loaded.
[21:29:55.216] using metadata XML ID read_evo9 from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_evo9.xml
[21:29:55.257] flashing tool "wrx02" loaded.
[21:29:55.268] flashing tool "wrx04" loaded.
[21:29:55.278] flashing tool "sti04" loaded.
[21:29:55.289] flashing tool "sti05" loaded.
[21:29:55.300] flashing tool "mitsucan" loaded.
[21:29:55.300] flashing tool "mitsukernel" loaded.
[21:29:55.300] flashing tool "mitsukernelocp" loaded.
[21:29:55.300] flashing tool "mitsubootloader" loaded.
[21:29:55.300] flashing tool "shbootmode" loaded.
[21:29:55.301] flashing tool "shaudmode" loaded.
[21:29:55.312] flashing tool "subarucan" loaded.
[21:29:55.323] flashing tool "subarucand" loaded.
[21:29:55.335] flashing tool "subarubrz" loaded.
[21:29:55.346] flashing tool "subaruhitachi" loaded.
for what ever reason the read from ECU tab stays gray and it does not read my ecu. I uninstall and installed ecuflash bunch of times i also downloaded the drivers few times but nothing seems to do the trick. any idea what i can do? this is really annoying. i did read few threads about not being able to hook up but none seem to help. any idea is greatly appreciate it.
Thanks in advance,
Ben
Old Apr 25, 2016, 09:55 PM
which cable version are you using? At the bottom right of ecuflash it should show the cable you have plugged in. If it says "No vehicle interface" its not recognizing your cable. If it is showing your cable you may need to select your car under ECU->Select vehicle type.
Old Apr 25, 2016, 10:01 PM
benIX's Avatar
ya it does say No vehicle interface?? so what do i have to do for it to recognize the cable?
Old Apr 25, 2016, 10:08 PM
edsct9a's Avatar
I can't read or write to my ecu with ecuflash so I use EvoScan for that. If you have that try it and see if it works.
Old Apr 25, 2016, 10:14 PM
kaj
kaj's Avatar
Make sure the key is on. Obvious, I know...But gotta start there. LOL
Then make sure your COM ports are set up.
Old Apr 26, 2016, 07:59 AM
Its probably a problem with your windows drivers. Download the most recent version of ecuflash from tactrix site and then uninstall the version you have and install the new one. That should install the drivers. Then try plugging the cable in again and it should recognize it. If not then additional trouble shooting will be required. What version of the cable do you have?
Quick Reply: CA smog😡
