How to install the spark plug anti-foulers to remove the ses or cel light
Old Jun 20, 2005, 05:12 PM
  #31
EvilBlueEvo8's Avatar
Originally Posted by Zeus
AutoZone, O'Reily's, Pepboys, etc... and don't "clean" your sensor!
thanks. i didn't think you were supposed to clean the sensor but i saw that and had my doubts.
Old Jun 20, 2005, 05:21 PM
  #32
xiaoni420's Avatar
has anyone done this with the HKS carbon-ti? i dont think im going to have enough room to work with down there. the sensor alone is pretty close to the bottom of the car. let me know
Old Jun 29, 2005, 05:40 PM
  #33
could only fit one on my buschur tb. hopefully it works
Old Jun 29, 2005, 06:13 PM
  #34
Zeus's Avatar
I threw a CEL with only one... I hope you have better luck... some have, but I would think you would have to drill a very "true" hole to make it work this way.
Old Jun 29, 2005, 06:30 PM
  #35
what do you mean by true? perfectly centered? and if so, why do you think that?
Old Jun 29, 2005, 07:16 PM
  #36
Zeus's Avatar
I "think that" because the "mechanism" (or lack there of) by which this works is in limiting how much exhaust gas reaches the sensor. Common sense dictates that if the hole is off center/canted/ob-longed etc then more gas may enter the sensor at a given point than the minimum amount necessary to keep the sensor "happy", but not trigger a code.
Old Aug 11, 2005, 07:37 AM
  #37
twan's Avatar
Tried with Both anti-foulers last night.
Plenty of room on the RNR custom HKS carbon/ti TB setup.
Will report back if I get a light.
Old Sep 5, 2005, 08:22 PM
  #38
bcampbell782's Avatar
Rnr carbon ti works like a champ so far, plenty of room, thanks for the tip.
Old Sep 10, 2005, 01:03 AM
  #39
erioshi's Avatar
I've had this solution in place since for well over a rear now now without problems. I did need to "adjust" the heat shield slightly to clear everything correctly.
Old Sep 27, 2005, 08:53 PM
  #40
brooks1005's Avatar
I had used one anti-fouler for about 3 months then the cel lit this weekend.Two won't fit so I'm trying to find a 90 deg.elbow bend.
Old Oct 15, 2005, 11:48 PM
  #41
akemi27's Avatar
would this fix clear you for emissions too?! (wishful thinking :L)
Old Nov 2, 2005, 10:06 AM
  #42
smoothmarine187's Avatar
20,000 miles later......and still no CEL, and yes I passed emissions with no problem!
Old Nov 9, 2005, 10:16 AM
  #43
Evo VIII 4G63's Avatar
how is it on the ams turbo back anyone throwing codes with it yet. And also how is the clearence with the two of them in at the same time with the ams
Old Apr 10, 2006, 09:39 AM
  #44
evozakk's Avatar
Bringing it back from the dead but I have the AMS tbe and WAS throwing a code, but the anti-foulers worked for it, no more light.
Old May 7, 2006, 06:02 PM
  #45
apevo8's Avatar
just did this today...took like 30 minutes and $8....perfect fit.....couldnt go wrong with this technique...highly recommend whoever has a straight pipe...DO THIS!
Quick Reply: How to install the spark plug anti-foulers to remove the ses or cel light
