Old Jul 11, 2008 | 11:45 AM
  #2206
SHhhhh's Avatar
Please post some daylight pics of the rear fender rolling please!
Originally Posted by theshadow
OK I hope I qualify...
Wheels - Rota P45R 18x9.5+27 Offset
Tires - Pirelli Corsa 285/30/18
No spacers + major rear fender rolling
(sorry for the camera phone pic quality)
Old Jul 11, 2008 | 12:23 PM
  #2207
Mitchubishievo's Avatar
Dammit I can't wait to post in here...
Old Jul 11, 2008 | 12:31 PM
  #2208
Evo Tengoku's Avatar
I didn't even notice the rear fender rolling. Danng good job!
Old Jul 11, 2008 | 12:49 PM
  #2209
SHhhhh's Avatar
You scare me Mitch
Old Jul 11, 2008 | 03:24 PM
  #2210
theshadow's Avatar
Originally Posted by h22gordo
^ Wow!
Those Pirelli Corsa Tires are more expensive than those Rota's! lol
Car looks great regardless!
But coming from Dubai, I was expecting gold plated unobtanium wheels, not Rota's!
LOL! You're actually right...I paid about double for the tires compared to what I did for the rims!
I'm competing in a summer Sprint series here (hence the reason for having huge stickers on the car) and wanted to try out 285 semislicks in the name of being as competitive in my class as possible and, well, just to see the difference between these and the numerous sets of 235/245 semis I've been running in terms of grip. I've seen some guys like EVOlutionary and Warrtalon running 285/30s so thought I'd give it a shot.
I bought the Rotas used off a guy here who tracks a 350Z. He likes to run the same size all around as opposed to the usual staggered 350Z setup so these are basically four 350Z REAR rims I'm running right now. Got a great deal on them but they weigh a TON (something like 23 lbs per corner) so I'm looking at those Enkei RCT4s that Speed Element's got right in order to shed a few pounds
The level of fender rolling I had done is not for the faint of heart - the rear fenders are rolled and pulled to the max. I basically told the bodyshop guys to do anything possible to get the fenders to clear the tires no matter what it looked like
The rear fenders rolled so much that the sheet metal above the arches where they're rolled actually got dented IN under the pressure and had to be hammered out again. It's a pretty clean job but I do need to send it back to the bodyshop for a little extra finishing work next week.
Good news is that they do clear though and no rubbing - and that's under track conditions! In the front, you need to watch for clearance between the springs and inner side of the tires - I had to set the camber bolts on the hubs to MIN camber and then MAX camber on the camber plates - works out to -2.4 camber up front which is perfect.
I also noticed that the inside of the fronts tend to rub the frame of the car when I'm at full lock, as well as a bit of rubbing on the fender liners.
Pulling 1.2 lateral Gs at will is worth all the hassle though
Old Jul 12, 2008 | 07:45 PM
  #2211
Jean's Avatar
Volk GT-F
-19 x 9.5 +30
-245/35/19 Nitto Invo's
Old Jul 12, 2008 | 11:17 PM
  #2212
atomicapples's Avatar
if you find out a way to mod your fender liner so it dont rub, please tell!!!...
i musta went thru 3 sets of liners since my wheel install...
Old Jul 12, 2008 | 11:31 PM
  #2213
essjEVO's Avatar
lol you just take em out... =)
Old Jul 13, 2008 | 08:32 AM
  #2214
I rubbed my frame with some mere 265's .
Old Jul 13, 2008 | 01:16 PM
  #2215
MJ23FE's Avatar
4x4 status
18x9.5 +34 Volk CE28N Time Attacks
255/35R18 Toyo Proxes T1R
Stock Suspension
-Jalal
Old Jul 13, 2008 | 07:22 PM
  #2216
^ That's not aggresive otherwise I would've posted in here a while back ^. Looks good otherwise.
Old Jul 14, 2008 | 07:04 AM
  #2217
turbogst311's Avatar
The rims on the gg evo are sexy
Old Jul 15, 2008 | 12:32 PM
  #2218
theEVOdream's Avatar
^18 x 9.5 NT03+M +27 offset all around
^265 35 18 michelin pilot sport ps2
^13mm spacers up front + ARP extended studs
^megan track coilovers and rear fenders rolled + pulled
...dont ask about the valve stems, it will be fixed.
haven't figured out if I want to pull the front liner yet...and sorry for the crappy photos!! lol
Old Jul 15, 2008 | 12:47 PM
  #2219
DarksideEng's Avatar
Looks good I will get you the valvestems you need.
Old Jul 15, 2008 | 01:18 PM
  #2220
appreciate it!! Enkei forgot to add two I guess... Thanks again Logan!
