Inside Fuse source for 12V constant
I'm trying to find a fuse in the fusebox on the inside of the car that will provide a 12v constant (always on even if ignition is off). I would rather not have to try to pass through the firewall to get to the fuses under the hood if I can avoid it.
I tested and the cigarette lighter is not on with the key out/off.
There are empty slots and something labeled engine control but I don't know what they do.
Anyone know of anything on the inside fuse box I can use?
Thanks....I'm looking for sources on the inside fuse box. The horn, hazzards, brake lights... are under the hood fuses.
The radio may be a possibility of the dome light fuse doesn't work out but I'm not sure what radio wire and I'd rather tap a fuse and not mess with the factory wires in case I have to remove it.
Just test the pins in the fuse box with a volt meter with the key off if you didn't try that allready.......... You'll also want to put an in-line fuse to the light so you don't run too many amps into it, the light should be rate. It should prolly only need 1-2 Amps......
Also there are two power wires that run to the radio, the Battery wire and memory wire, test them and see which one has power with the key off and use that one, don't forget about the fuse...
